跳转到主内容
Palm Centro Speakers Replacement
你所需要的
  1. Palm Centro Speakers Replacement, Disassembling Palm Centro Battery: 步骤 1 中的图像 1,2 Palm Centro Speakers Replacement, Disassembling Palm Centro Battery: 步骤 1 中的图像 2,2
    • Press and slide open the battery cover.
  2. Palm Centro Speakers Replacement: 步骤 2 中的图像 1,1
    • Caution: Turn cell phone off before removing battery!
    • Press battery to the right.
    • Then lift up battery pack to remove.
  3. Palm Centro Speakers Replacement: 步骤 3 中的图像 1,1
    • Phone with battery removed
  4. Palm Centro Speakers Replacement, Back Housing: 步骤 4 中的图像 1,1
    • Remove the touchpad pen from the top left corner on the back to reveal the last of 6 screws to be removed.
  5. Palm Centro Speakers Replacement: 步骤 5 中的图像 1,1
    • Lift the rubber cap at the top right to reveal the sixth screw.
    • Caution: There is a small Palm sticker under the rubber cap. Tampering with or removing this sticker will void your warranty!
    • Remove the six screws using the T5 Torx screwdriver.
  6. Palm Centro Speakers Replacement: 步骤 6 中的图像 1,2 Palm Centro Speakers Replacement: 步骤 6 中的图像 2,2
    • Remove the SIM card so housing can be separated.
  7. Palm Centro Speakers Replacement: 步骤 7 中的图像 1,2 Palm Centro Speakers Replacement: 步骤 7 中的图像 2,2
    • Use a plastic pry tool to separate the bottom of the case to remove the small plastic insert.
  8. Palm Centro Speakers Replacement: 步骤 8 中的图像 1,2 Palm Centro Speakers Replacement: 步骤 8 中的图像 2,2
    • Remove the small plastic insert at the bottom of the phone.
  9. Palm Centro Speakers Replacement: 步骤 9 中的图像 1,2 Palm Centro Speakers Replacement: 步骤 9 中的图像 2,2
    • Continue with plastic pry tool all the way around the phone to remove the back housing.
  10. Palm Centro Speakers Replacement, Logic Board: 步骤 10 中的图像 1,1
    • Carefully peel back the tape holding the speaker (left) and keyboard (right) connection tabs in place.
  11. Palm Centro Speakers Replacement: 步骤 11 中的图像 1,1
    • Using the plastic prying tool, lift the tabs and carefully pull the contact connections out on both sides.
    • Be very careful, these electronics are delicate!
  12. Palm Centro Speakers Replacement: 步骤 12 中的图像 1,1
    • Separate the logic board from the case by lifting and pulling out the bottom.
  13. Palm Centro Speakers Replacement, Speakers: 步骤 13 中的图像 1,3 Palm Centro Speakers Replacement, Speakers: 步骤 13 中的图像 2,3 Palm Centro Speakers Replacement, Speakers: 步骤 13 中的图像 3,3
    • Pry the four plastic latches free that connect the antenna to the logic board.
    • Excessive force may damage your logic board!
    • Remove the antenna from the logic board.
  14. Palm Centro Speakers Replacement: 步骤 14 中的图像 1,1
    • The internal speaker is attached to the antenna. To remove it, pry the speaker from the antenna using the tip of your screwdriver.
    • The speaker should be placed back into its spot in the correct position. Take notice of the gold connectors
结论
另外一个人完成了本指南。
Kevin
于04/12/10注册
31 声望
撰写一个指南
团队
Cal Poly, Team 15-49, Garner Spring 2010 Cal Poly, Team 15-49, Garner Spring 2010 的会员
CPSU-GARNER-S10S15G49
5 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,488
