跳转到主内容
Palm Centro Back Housing Replacement
你所需要的
  1. Palm Centro Back Housing Replacement, Disassembling Palm Centro Battery: 步骤 1 中的图像 1,2 Palm Centro Back Housing Replacement, Disassembling Palm Centro Battery: 步骤 1 中的图像 2,2
    • Press and slide open the battery cover.
  2. Palm Centro Back Housing Replacement: 步骤 2 中的图像 1,1
    • Caution: Turn cell phone off before removing battery!
    • Press battery to the right.
    • Then lift up battery pack to remove.
  3. Palm Centro Back Housing Replacement: 步骤 3 中的图像 1,1
    • Phone with battery removed
  4. Palm Centro Back Housing Replacement, Back Housing: 步骤 4 中的图像 1,1
    • Remove the touchpad pen from the top left corner on the back to reveal the last of 6 screws to be removed.
  5. Palm Centro Back Housing Replacement: 步骤 5 中的图像 1,1
    • Lift the rubber cap at the top right to reveal the sixth screw.
    • Caution: There is a small Palm sticker under the rubber cap. Tampering with or removing this sticker will void your warranty!
    • Remove the six screws using the T5 Torx screwdriver.
  6. Palm Centro Back Housing Replacement: 步骤 6 中的图像 1,2 Palm Centro Back Housing Replacement: 步骤 6 中的图像 2,2
    • Remove the SIM card so housing can be separated.
  7. Palm Centro Back Housing Replacement: 步骤 7 中的图像 1,2 Palm Centro Back Housing Replacement: 步骤 7 中的图像 2,2
    • Use a plastic pry tool to separate the bottom of the case to remove the small plastic insert.
  8. Palm Centro Back Housing Replacement: 步骤 8 中的图像 1,2 Palm Centro Back Housing Replacement: 步骤 8 中的图像 2,2
    • Remove the small plastic insert at the bottom of the phone.
  9. Palm Centro Back Housing Replacement: 步骤 9 中的图像 1,2 Palm Centro Back Housing Replacement: 步骤 9 中的图像 2,2
    • Continue with plastic pry tool all the way around the phone to remove the back housing.
结论
2等其他人完成本指南。
团队
Cal Poly, Team 15-49, Garner Spring 2010 Cal Poly, Team 15-49, Garner Spring 2010 的会员
CPSU-GARNER-S10S15G49
5 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 3,762
