跳转到主内容
Packard Bell ms-Hera c Disassembly
你所需要的
  1. Packard Bell ms-Hera c Disassembly, Unscrew the lid: 步骤 1 中的图像 1,3 Packard Bell ms-Hera c Disassembly, Unscrew the lid: 步骤 1 中的图像 2,3 Packard Bell ms-Hera c Disassembly, Unscrew the lid: 步骤 1 中的图像 3,3
    • Remove the battery.
    • Unscrew the red marked screws with a Phillips screwdriver.
    • Remove the DVD reader.
  2. Packard Bell ms-Hera c Disassembly, Disconnect the keyboard: 步骤 2 中的图像 1,3 Packard Bell ms-Hera c Disassembly, Disconnect the keyboard: 步骤 2 中的图像 2,3 Packard Bell ms-Hera c Disassembly, Disconnect the keyboard: 步骤 2 中的图像 3,3
    • Pry in the red marked spots to release the keyboard
    • Unplug the keyboard connector.
  3. Packard Bell ms-Hera c Disassembly, Unplug the cables: 步骤 3 中的图像 1,3 Packard Bell ms-Hera c Disassembly, Unplug the cables: 步骤 3 中的图像 2,3 Packard Bell ms-Hera c Disassembly, Unplug the cables: 步骤 3 中的图像 3,3
    • Unplug the 3 connectors on the motherboard
    • Remove the 2 screws holding the display in place
    • Use a thin tool to pry up the back cover of the laptop on the side
  4. Packard Bell ms-Hera c Disassembly, Unscrew the motherboard: 步骤 4 中的图像 1,3 Packard Bell ms-Hera c Disassembly, Unscrew the motherboard: 步骤 4 中的图像 2,3 Packard Bell ms-Hera c Disassembly, Unscrew the motherboard: 步骤 4 中的图像 3,3
    • Remove the back cover.
    • Remove the HDD.
    • Remove the screws that hold the motherboard.
  5. Packard Bell ms-Hera c Disassembly, Remove the display: 步骤 5 中的图像 1,3 Packard Bell ms-Hera c Disassembly, Remove the display: 步骤 5 中的图像 2,3 Packard Bell ms-Hera c Disassembly, Remove the display: 步骤 5 中的图像 3,3
    • Remove the marked screws and connectors.
    • Disconnect the display connector.
    • Remove the display.
  6. Packard Bell ms-Hera c Disassembly, Remove the heatsink: 步骤 6 中的图像 1,3 Packard Bell ms-Hera c Disassembly, Remove the heatsink: 步骤 6 中的图像 2,3 Packard Bell ms-Hera c Disassembly, Remove the heatsink: 步骤 6 中的图像 3,3
    • Remove the cooling fan.
    • Remove the heatsink.
    • Remove the screws on the connector.
  7. Packard Bell ms-Hera c Disassembly, Remove the motherboard: 步骤 7 中的图像 1,2 Packard Bell ms-Hera c Disassembly, Remove the motherboard: 步骤 7 中的图像 2,2
    • Remove the screws to remove the motherboard.
结论
2等其他人完成本指南。
由衷感谢以下译者:
it en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Smilzo
于11/09/13注册
11,849 声望
创作了39篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 40
总计 1,461
