跳转到主内容
Packard Bell EasyNote TJ65-CU-030GE Battery Replacement
  1. Packard Bell EasyNote TJ65-CU-030GE Battery Replacement, Battery: 步骤 1 中的图像 1,2 Packard Bell EasyNote TJ65-CU-030GE Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • The battery is located on the top left corner of the backside of the device.
    • On the left side underneath the battery drawer, you can see two battery lock switches located in the shape of a T.
    • At the beginning, both switches should be switched to the locked position.
  2. Packard Bell EasyNote TJ65-CU-030GE Battery Replacement: 步骤 2 中的图像 1,3 Packard Bell EasyNote TJ65-CU-030GE Battery Replacement: 步骤 2 中的图像 2,3 Packard Bell EasyNote TJ65-CU-030GE Battery Replacement: 步骤 2 中的图像 3,3
    • Slide the vertical battery lock switch downwards to the image of the unlocked padlock.
    • Now you can move the horizontal battery lock switch to the right.
    • You need to apply some pressure to fully move over the switch. At the hardest part, the battery drawer will spring open.
    • Now you can remove the battery block completely.
    • By doing this, the horizontal switchlock will jump back to its original position on the left side.
结论
5等其他人完成本指南。
Jasmin
于02/17/16注册
407 声望
撰写一个指南
团队
iFixit EU Team iFixit EU Team 的会员
Staff
46 名成员
创作了1,092篇指南
3条评论
I am trying to find out how I have managed to turn off the battery on my packardbell easy note ENTG71BM. Any ideas?
julie crockford - 回复
I am tring to turn on the pc, but the only thing it does is making noise of the fan repeatedly without lighting the screen.
siyabonga - 回复
Solution could be as simple as selecting the right video output mode, follow the first hint from the most useful answer in this thread https://it.ifixit.com/Risposte/Visualizz.... If it helped you solve your problem, please feel free to leave a feedback to the author of the post, otherwise I suggest you try asking directly in the above-mentioned dedicated topic
Simone -
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 66
总计 7,306
