跳转到主内容
Packard Bell 4X4 Desktop Drive Cage Replacement
你所需要的
  1. Packard Bell 4X4 Desktop Drive Cage Replacement, Top Cover: 步骤 1 中的图像 1,1
    • Using a Phillips screwdriver, remove the three Phillips head screws (circled in red) from the back of the computer.
  2. Packard Bell 4X4 Desktop Drive Cage Replacement: 步骤 2 中的图像 1,1
    • With both hands on each side of the case, slide the top cover toward you. Lift it off the computer.
  3. Packard Bell 4X4 Desktop Drive Cage Replacement: 步骤 3 中的图像 1,1
    • The top cover is removed.
  4. Packard Bell 4X4 Desktop Drive Cage Replacement, Drive Cage: 步骤 4 中的图像 1,1
    • Remove the two Philips head screws with your Philips screwdriver. You may have to lubricate these screws as they can be very difficult to remove.
  5. Packard Bell 4X4 Desktop Drive Cage Replacement: 步骤 5 中的图像 1,1
    • Remove the 1 Philips head screw from the left hand side of the case if there is one. Again, you may need to lubricate this screw.
  6. Packard Bell 4X4 Desktop Drive Cage Replacement: 步骤 6 中的图像 1,1
    • Once the screws are removed, disconnect all cables from the optical drive, hard drive and floppy drive.
  7. Packard Bell 4X4 Desktop Drive Cage Replacement: 步骤 7 中的图像 1,1
    • Slide the drive cage back. An easy way to do this is the push on the optical drive from the front.
  8. Packard Bell 4X4 Desktop Drive Cage Replacement: 步骤 8 中的图像 1,1
    • Lift the drive cage up and out of the computer.
结论
2等其他人完成本指南。
Brandon S
于09/04/10注册
490 声望
创作了3篇指南
团队
Packard Bell Planet Packard Bell Planet 的会员
Community
1 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 9
总计 1,865
