简介
If you find that your scanner is making strange noises or still fails to function properly, the motor might be jammed or need replacing. This guide will help you remove the motor from the inner casing.
你所需要的
To start, open the device by removing the 5, 5mm x 9mm screws, with a Phillips J1 screwdriver.
结论
