跳转到主内容
Pacific Image Electronics CS3600 Motor Replacement
你所需要的
  1. Pacific Image Electronics CS3600 Motor Replacement, Motor: 步骤 1 中的图像 1,2 Pacific Image Electronics CS3600 Motor Replacement, Motor: 步骤 1 中的图像 2,2
    • To start, open the device by removing the 5, 5mm x 9mm screws, with a Phillips J1 screwdriver.
  2. Pacific Image Electronics CS3600 Motor Replacement: 步骤 2 中的图像 1,1
    • Next, remove the 5 9mm x 5mm screws from the circled spots with a Phillips J1 screwdriver.
  3. Pacific Image Electronics CS3600 Motor Replacement: 步骤 3 中的图像 1,1
    • Once the screws are removed, carefully lift the motor casing out of the device.
    • The plastic piece circled acts as a clamp, lift the casing up and towards you to detach the casing.
  4. Pacific Image Electronics CS3600 Motor Replacement: 步骤 4 中的图像 1,2 Pacific Image Electronics CS3600 Motor Replacement: 步骤 4 中的图像 2,2
    • Now, with the motor casing in hand, remove the two 9mm x 5mm screw and washer at the top of the motor casing using a J1 screwdriver.
    • Gently pull the motor away from the casing to expose the wires.
  5. Pacific Image Electronics CS3600 Motor Replacement: 步骤 5 中的图像 1,1
    • Carefully desolder the wires from their contact point on the circuit board.
    • You have now successfully removed the motor!
结论
Alessia Carlton
于03/21/17注册
201 声望
创作了2篇指南
团队
Texas Tech, Team S46-G2, Bennett Spring 2017 Texas Tech, Team S46-G2, Bennett Spring 2017 的会员
TTU-BENNETT-S17S46G2
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 12
总计 231
