跳转到主内容
加入维修社区 - 创建账户
Pacific Image Electronics CS3600 Button Spring Replacement
你所需要的
  1. Pacific Image Electronics CS3600 Button Spring Replacement, Button Spring: 步骤 1 中的图像 1,1
    • Begin opening the device by unscrewing the 5 following 9mm x 7mm screws with a J1 screwdriver.
  2. Pacific Image Electronics CS3600 Button Spring Replacement: 步骤 2 中的图像 1,1
    • Once the screws have been removed, with light force open the scanner by pulling it apart at the seam.
  3. Pacific Image Electronics CS3600 Button Spring Replacement: 步骤 3 中的图像 1,1
    • With a JIS J0 screwdriver remove the 1 screw that is 7mm x 6mm.
  4. Pacific Image Electronics CS3600 Button Spring Replacement: 步骤 4 中的图像 1,1
    • Lift and move the plate with the connected wires out of the way.
  5. Pacific Image Electronics CS3600 Button Spring Replacement: 步骤 5 中的图像 1,1
    • Remove the spring and replace it with a new one.
结论
Amber Berry
于03/21/17注册
101 声望
撰写一个指南
团队
Texas Tech, Team S46-G2, Bennett Spring 2017 Texas Tech, Team S46-G2, Bennett Spring 2017 的会员
TTU-BENNETT-S17S46G2
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 285
