跳转到主内容
PSP Go Trigger buttons Replacement
你所需要的
  1. PSP Go Trigger buttons Replacement, Back Cover: 步骤 1 中的图像 1,2 PSP Go Trigger buttons Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Unscrew the four Phillips screws on the back of the PSP Go.
    • Rotate the PSP so you can see the top of the device.
    • Unscrew the two Phillips screws next to the volume buttons.
  2. PSP Go Trigger buttons Replacement: 步骤 2 中的图像 1,2 PSP Go Trigger buttons Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool around the perimeter of the back cover to loosen it on all sides.
    • Open the back cover by gently lifting the right side, and rotating it to the left side (as if you were opening a book).
    • Be careful not to rotate the back cover from the bottom, as you will break the plastic screw holes on top of the device.
  3. PSP Go Trigger buttons Replacement, Top Cover: 步骤 3 中的图像 1,1
    • Pull the top cover upwards gently from its housing.
  4. PSP Go Trigger buttons Replacement, Trigger buttons: 步骤 4 中的图像 1,1
    • The top cover will most likely come off during the repair, so might as well take it off now. Pull it upwards gently from its housing.
  5. PSP Go Trigger buttons Replacement: 步骤 5 中的图像 1,1
    • The procedure is exactly the same for the left trigger button.
    • Use a plastic opening tool to gently flip up the left trigger connector.
  6. PSP Go Trigger buttons Replacement: 步骤 6 中的图像 1,2 PSP Go Trigger buttons Replacement: 步骤 6 中的图像 2,2
    • Unscrew the lone Phillips screw holding the trigger in place. Remove both trigger and retaining plate from the PSP Go.
    • If necessary, repeat steps 2 and 3 to remove the right trigger button.
结论
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 41
总计 12,328
