跳转到主内容
PSP Go Bottom Plate Replacement
你所需要的
  1. PSP Go Bottom Plate Replacement, Back Cover: 步骤 1 中的图像 1,2 PSP Go Bottom Plate Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Unscrew the four Phillips screws on the back of the PSP Go.
    • Rotate the PSP so you can see the top of the device.
    • Unscrew the two Phillips screws next to the volume buttons.
  2. PSP Go Bottom Plate Replacement: 步骤 2 中的图像 1,2 PSP Go Bottom Plate Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool around the perimeter of the back cover to loosen it on all sides.
    • Open the back cover by gently lifting the right side, and rotating it to the left side (as if you were opening a book).
    • Be careful not to rotate the back cover from the bottom, as you will break the plastic screw holes on top of the device.
  3. PSP Go Bottom Plate Replacement, Top Cover: 步骤 3 中的图像 1,1
    • Pull the top cover upwards gently from its housing.
  4. PSP Go Bottom Plate Replacement, Bottom Plate: 步骤 4 中的图像 1,2 PSP Go Bottom Plate Replacement, Bottom Plate: 步骤 4 中的图像 2,2
    • Remove the two Phillips screws holding the bottom plate.
    • Gently lift the bottom plate away from the device.
结论
2等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 34
总计 7,642
