简介
This guide shows how to remove the PSP Go's battery.
你所需要的
Unscrew the four Phillips screws on the back of the PSP Go.
Rotate the PSP so you can see the top of the device.
Unscrew the two Phillips screws next to the volume buttons.
Use the plastic opening tool to gently peel away at the "Warranty Void" sticker. Start on one edge, as shown, and slide the tool from side to side until the sticker is removed from just the battery.
Gently pull the sticker away from the battery connector, just enough so that the connector is visible.
Wedge a plastic opening tool in between the connector and logic board, and gently pull the connector upwards.
If you are having trouble charging up your system. Try reseating the battery connector of this step before purchasing a new battery. This is a common problem with PSP go systems that haven't been used for a while. If the battery still doesn't charge after reseating the connector, you might need a new battery.
20等其他人完成本指南。
12指南评论
this was so quick . I have been trying to get this repaired for years, only to hear throw it away there is no fix . sharing love
a couple of notes my cover came completely off in the beginning step without a problem or broken screws. next i didnt und the wired cabled beside the clicker and it wasnt in the way.
After replace a new battery my psp go going crazy. Charge only 1 or 2 min led going to green but not fully charge. Anyone can help me to fix this
Cfw 6.61 pro update. Helppp
Thanks to this guide I was able to reseat the battery, the PSP was not turning on or charging any more, now everything is working again.
Excellent guide, PSP go works like new!
I bought a replacement battery online for my PSP Go, but it came without the white connector. Have you an idea how to fix it?
My psp go is not charging but when I connect it my laptop is get connected any idea what is going on
I knew how to do it but I love this site and it does help
Amazing guide that makes the process simple! As a heads up for future users of the guide: If you are having trouble charging the battery of your PSP go, try reseating the battery connector. and check if the device starts charging. This is a common problem with PSP go's that have sat dormant for a while. You might not need a new battery and just need to reseat the old ones connector. I hope this comment might save someone time and money! Cheers!
How can I reset the battery?
You will need to open up the consoles back cover and then carefully unplug thr battery connector and then plug it back in.
FinWZ -
