跳转到主内容
加入维修社区 - 创建账户
PSP E1000 Screen black
你所需要的
  1. PSP E1000 Screen black, PSP E1000 Screen black: 步骤 1 中的图像 1,1
    • This is the front and back of the PSP E1000
  2. PSP E1000 Screen black: 步骤 2 中的图像 1,2 PSP E1000 Screen black: 步骤 2 中的图像 2,2
    • Remove all four screws on the back using the same bit as before.
    • Then remove the two top screws.
  3. PSP E1000 Screen black: 步骤 3 中的图像 1,1
    • Insert wisdom here.Gently unclip the display ribbon cable and remove it Then set the display to the side Untape the front panel ribbon cable, unclip it, then remove it.
  4. PSP E1000 Screen black: 步骤 4 中的图像 1,1
    • Remove the ribbon cable and power cable Gently lift the button assembly and charge port The shoulder button is taped down so slide a spudger under the button and gently peel it off
  5. PSP E1000 Screen black: 步骤 5 中的图像 1,1
    • Unclip and remove the two marked ribbon cables Remove the marked screw and lift the analog stick out Lift the button pad carefully and peel off the shoulder button When reassembling install the joystick before the buttons.
  6. PSP E1000 Screen black: 步骤 6 中的图像 1,1
    • Unclip both ribbon cables and remove them Remove the marked screw on the mainboard Lift the bottom of the mainboard up and slide it out For reinstallation make sure that the power switch cover is installed before it is screwed in. It has to be unscrewed to do the installation
  7. PSP E1000 Screen black: 步骤 7 中的图像 1,1
    • Congratulations you have disassembled your PSP E1000. Have fun with the reassembly!
  8. PSP E1000 Screen black: 步骤 8 中的图像 1,1
    • disassemble the console, take a multimeter and measure whether the fuse conducts current, if not, remove the fuse with scissors from a 3D printer or pliers and connect the 2 elements together
  9. PSP E1000 Screen black: 步骤 9 中的图像 1,1
    • here is the fuse
结论
另外一个人完成了本指南。
Błażej Stosio
于05/14/25注册
199 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 41
过去 30 天: 133
总计 1,153
