跳转到主内容
PSP E1000 LED Driver Circuit Component Replacement
你所需要的
  1. PSP E1000 LED Driver Circuit Component Replacement, Backlight electronic after water damage: 步骤 1 中的图像 1,1
    • this picture was made after cleaning
  2. PSP E1000 LED Driver Circuit Component Replacement: 步骤 2 中的图像 1,2 PSP E1000 LED Driver Circuit Component Replacement: 步骤 2 中的图像 2,2
    • it took me some time to find the right chip:
    • 1 - TB62752AFUG
    • 2 - Inductor 22µH/0.66A
    • 3 - MSS1P4-M3/89A
    • 4 - 2.2µF / 6,3V
    • 5 - Fuse 0.5A 0603
    • 6 - 1.0µF / 50V
    • 7 - Ferrite bead 30Ohm/3A
终点
11等其他人完成本指南。
Steven
于05/06/14注册
416 声望
撰写一个指南
7指南评论
Hi Steven,
Thank for your guide. It helped me restore my PSP street (in my case, the fuse was broken). But one more problem is my PSP street has no sound on speaker, but has sound on headphone. Can you give me a glue to fix?
Thank you.
Hoang Binh - 回复
I fixed it! There a broken fuse near the audio ic. Hooray!!!
Hoang Binh -
Hello Hoang Binh, I have the same problem as you, after changing the fuse to illuminate the display, no sound is heard through the speaker (only when connecting headphones, through them). Can you tell me, please, which is the fuse has been changed to solve the sound problem? An image whit the fuse be very helpful.
Olivian -
Hi @olivian. Sorry for late reply. I didn’t take any picture so I cannot point it out exactly. But you can find it yourself. Fuses often have a letter F or FB on it or its color is blue.
Hoang Binh - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 38
过去 30 天: 154
总计 12,817
