跳转到主内容
加入维修社区 - 创建账户
PSP 300xc Power Switch Board Replacement
你所需要的
  1. PSP 300xc Power Switch Board Replacement, Battery: 步骤 1 中的图像 1,2 PSP 300xc Power Switch Board Replacement, Battery: 步骤 1 中的图像 2,2
    • Press the button securing the battery door to the PSP 300xc, and lift the battery door off.
    • Lift the battery out of the PSP.
  2. PSP 300xc Power Switch Board Replacement, Front Case: 步骤 2 中的图像 1,1
    • Use a spudger or your fingernail to remove the warranty sticker stuck to the inside of the battery tray
  3. PSP 300xc Power Switch Board Replacement: 步骤 3 中的图像 1,2 PSP 300xc Power Switch Board Replacement: 步骤 3 中的图像 2,2
    • Remove four Phillips screws from the back of the PSP.
  4. PSP 300xc Power Switch Board Replacement: 步骤 4 中的图像 1,1
    • Remove two Phillips screws from the top of the PSP.
  5. PSP 300xc Power Switch Board Replacement: 步骤 5 中的图像 1,1
    • Remove a single screw from the bottom edge of the PSP.
  6. PSP 300xc Power Switch Board Replacement: 步骤 6 中的图像 1,2 PSP 300xc Power Switch Board Replacement: 步骤 6 中的图像 2,2
    • Insert a spudger between the front case and PSP, and slide the spudger along the perimeter of the front case to remove it.
  7. PSP 300xc Power Switch Board Replacement, LCD: 步骤 7 中的图像 1,1
    • Remove a single Phillips screw securing the home bar to the PSP 300xc.
  8. PSP 300xc Power Switch Board Replacement: 步骤 8 中的图像 1,2 PSP 300xc Power Switch Board Replacement: 步骤 8 中的图像 2,2
    • Push the home bar to the right about 1cm to release a tab, and begin to lift the right end of the home bar slightly.
    • Do not attempt to remove the home bar yet, it is still attached to the PSP 300xc.
  9. PSP 300xc Power Switch Board Replacement: 步骤 9 中的图像 1,1
    • Insert a spudger under the LCD, beside the black plastic tab.
    • Push the LCD to the left and pry up to release the left edge of the LCD from under the plastic tab.
  10. PSP 300xc Power Switch Board Replacement: 步骤 10 中的图像 1,1
    • Push the LCD to the right and pry up to release the right edge of the LCD from under the plastic tab.
  11. PSP 300xc Power Switch Board Replacement: 步骤 11 中的图像 1,3 PSP 300xc Power Switch Board Replacement: 步骤 11 中的图像 2,3 PSP 300xc Power Switch Board Replacement: 步骤 11 中的图像 3,3
    • Rotate the LCD away from the PSP to reveal the LCD and home bar ribbon cables.
    • Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following four ZIF connectors:
    • Home bar cable
    • Microphone cable
    • LCD display data cable
    • Touchscreen cable
    • Be sure you are prying up on the retaining flap, not the socket itself
    • After flipping up the locking tabs on all four connectors, use your fingers or a spudger to gently pull the cables straight out of the connectors.
  12. PSP 300xc Power Switch Board Replacement: 步骤 12 中的图像 1,1
    • Remove the LCD from the PSP 300xc.
  13. PSP 300xc Power Switch Board Replacement, Home Bar: 步骤 13 中的图像 1,3 PSP 300xc Power Switch Board Replacement, Home Bar: 步骤 13 中的图像 2,3 PSP 300xc Power Switch Board Replacement, Home Bar: 步骤 13 中的图像 3,3
    • Lift the home bar up as high as it will go, but not so high that the wires disconnect.
    • Try to bend the small tab under the silver rim as little as possible it the following steps. The more you bend, the more likely it will snap.
    • Twist the home bar counter clockwise while carefully lifting it further. The left edge has to lift over the black plastic frame to allow it to rotate.
    • The home bar should now lift out of the PSP 300xc.
  14. PSP 300xc Power Switch Board Replacement, Trigger Buttons: 步骤 14 中的图像 1,2 PSP 300xc Power Switch Board Replacement, Trigger Buttons: 步骤 14 中的图像 2,2
    • Remove both trigger buttons by lifting them off the PSP 300xc.
  15. PSP 300xc Power Switch Board Replacement, Power Switch Board: 步骤 15 中的图像 1,1
    • Using a finger or spudger, flip up the retaining flap on the power switch board ribbon cable socket.
    • Pull the ribbon cable out of its socket.
  16. PSP 300xc Power Switch Board Replacement: 步骤 16 中的图像 1,1
    • Using the flat end of a spudger, pry the power switch board up and off the PSP 300xc.
    • Remove the power switch board from the PSP.
结论
另外一个人完成了本指南。
Matthew Newsom
于01/05/10注册
42,013 声望
创作了67篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 49
总计 8,994
