简介
更换Sony PSP-3000中故障定向垫的步骤
你所需要的
用撬棒或指甲剥去电池后面的保修标签。
This will end your warranty, so do it on your own risk!
Even though warranties are long expired on these things.
“IF” your on this Site “I FIX IT(tm) to lean how to repair something on your own… you “Should NOT” be too concerned about warranty any longer, as if you were .. for your iPhone or Pad etc… you would have taken it to the supplier.. No??
然后,从PSP的底部边缘(位于条形码旁边)上卸下单个螺钉。
“DON’T” forget to put your screws separately on a mag mat (Or sticky tape) so to 1) Not loose them & 2) Remember where they go as they may be of differing sizes. (Refer time the pictures also helps, but you can take a pic on your camera as you go to remind you also.
从“R”肩部按钮开始,将撬棒滑入PSP外壳之间,轻轻撬开外壳。
完全取下前壳。
J’ai récemment fait cette réparation et le boîtier avant ne voulait pas venir à condition d’enlever les deux vis sur le boîtier arrière au niveau du joystick et de la croix directionnelle. Il manque donc selon moi une partie mais je peux me tromper !
要重新组装设备,请按相反的顺序按照这些说明操作。
4等其他人完成本指南。
由衷感谢以下译者:
100%
le80259正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
