跳转到主内容
修复你的物品
维修的权力
商店
已存档
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
已存档
简介
How to change / replace joystick (analog stick).
视频概述
  1. Remove the battery and memory card! Remove the battery and memory card! Remove the battery and memory card!
    • Remove the battery and memory card!
  2. You have to remove seven screws. You have to remove seven screws. You have to remove seven screws.
    • You have to remove seven screws.
  3. The front face-plate. The front face-plate.
    • The front face-plate.
  4. The plate with volume-start-home key flex. The plate with volume-start-home key flex. The plate with volume-start-home key flex.
    • The plate with volume-start-home key flex.
  5. Be careful while removing the screen! Release the cables for screen and "volume-start-home keys"! Be careful while removing the screen! Release the cables for screen and "volume-start-home keys"! Be careful while removing the screen! Release the cables for screen and "volume-start-home keys"!
    • Be careful while removing the screen! Release the cables for screen and "volume-start-home keys"!
  6. Insert wisdom here. Insert wisdom here.
    • Insert wisdom here.
  7. Slightly lift the board and remove the joystick! Slightly lift the board and remove the joystick!
    • Slightly lift the board and remove the joystick!
  8. Now is the time for the new replacement part. Now is the time for the new replacement part.
    • Now is the time for the new replacement part.
  9. The assembling now is easy. The assembling now is easy. The assembling now is easy.
    • The assembling now is easy.
  10. That's all. I hope I've been helpful.
    • That's all. I hope I've been helpful.
结论
3等其他人完成本指南。
ZFix
于2013年12月09日注册
176,242 信誉积分
创作了316篇指南
团队
Master Techs Master Techs 的会员
Community
294 名成员
创作了957篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 5
总计 3,899
