跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
How to change / replace joystick (analog stick).
视频概述
  1. Remove the battery and memory card! Remove the battery and memory card! Remove the battery and memory card!
    • Remove the battery and memory card!
  2. You have to remove seven screws. You have to remove seven screws. You have to remove seven screws.
    • You have to remove seven screws.
  3. The front face-plate. The front face-plate.
    • The front face-plate.
  4. The plate with volume-start-home key flex. The plate with volume-start-home key flex. The plate with volume-start-home key flex.
    • The plate with volume-start-home key flex.
  5. 任天堂 Switch 套装
    A quick fix to get back in the game
    Shop Switch Kits
    任天堂 Switch 套装
    Shop Switch Kits
  6. Be careful while removing the screen! Release the cables for screen and "volume-start-home keys"! Be careful while removing the screen! Release the cables for screen and "volume-start-home keys"! Be careful while removing the screen! Release the cables for screen and "volume-start-home keys"!
    • Be careful while removing the screen! Release the cables for screen and "volume-start-home keys"!
  7. Insert wisdom here. Insert wisdom here.
    • Insert wisdom here.
  8. Slightly lift the board and remove the joystick! Slightly lift the board and remove the joystick!
    • Slightly lift the board and remove the joystick!
  9. Now is the time for the new replacement part. Now is the time for the new replacement part.
    • Now is the time for the new replacement part.
  10. The assembling now is easy. The assembling now is easy. The assembling now is easy.
    • The assembling now is easy.
  11. That's all. I hope I've been helpful.
    • That's all. I hope I've been helpful.
结论
3等其他人完成本指南。
ZFix
于2013年12月09日注册
169,091 信誉积分
创作了306篇指南
团队
Master Techs Master Techs 的会员
Community
292 名成员
创作了835篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 4
过去的30天: 10
总计 3,826
