跳转到主内容
PSP 2000 Front Casing Replacement
你所需要的
  1. PSP 2000 Front Casing Replacement, Battery: 步骤 1 中的图像 1,3 PSP 2000 Front Casing Replacement, Battery: 步骤 1 中的图像 2,3 PSP 2000 Front Casing Replacement, Battery: 步骤 1 中的图像 3,3
    • Place PSP face down, so that the UMD Drive is facing upwards.
    • Locate the battery door and open.
    • Remove the battery from inside.
  2. PSP 2000 Front Casing Replacement, Front Casing: 步骤 2 中的图像 1,1
    • This step requires the removal of the warranty sticker. Removing the sticker will void the warranty. According to the FTC removing this will not void your warranty.
    • Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
    • Remove the sticker using the PSP Opening Tools.
    • Under the sticker is a 5mm Phillips screw needed in the next step.
  3. PSP 2000 Front Casing Replacement: 步骤 3 中的图像 1,2 PSP 2000 Front Casing Replacement: 步骤 3 中的图像 2,2
    • Remove four 5 mm Phillips from the case.
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
  4. PSP 2000 Front Casing Replacement: 步骤 4 中的图像 1,2 PSP 2000 Front Casing Replacement: 步骤 4 中的图像 2,2
    • Remove the following screws from around the bezel:
    • Two 4 mm Phillips
    • One 5 mm Phillips
    • The two shorter 4 mm screws are on the top of the PSP; the longer 5 mm screw is on the bottom.
  5. PSP 2000 Front Casing Replacement: 步骤 5 中的图像 1,2 PSP 2000 Front Casing Replacement: 步骤 5 中的图像 2,2
    • Gently pry the front bezel away from the casing using a PSP opening tool.
    • Start on the right hand side of the PSP bezel, and carefully work the tool around the side.
    • If you want to clean the control buttons or D-pad, you can easily pop them out once the faceplate is off and wipe them clean.
结论
17等其他人完成本指南。
pepe32290
于10/19/09注册
1,738 声望
创作了4篇指南
团队
Cal Poly, Team 6-3, Maness Fall 2009 Cal Poly, Team 6-3, Maness Fall 2009 的会员
CPSU-MANESS-F09S6G3
5 名成员
创作了44篇指南
1指南评论
Does the front casing also have the plastic glass screen on it as well? Or is that separate?
Arthur - 回复
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 46
过去 30 天: 177
总计 30,246
