简介
Are you having problems with the touchpad on your PSKONTORORA LBER-P4-05, such as it not responding to any input? Well not to worry, this easy-to-follow guide will allow you to check what is going on within the controller.
你所需要的
Use blunt tweezers to pull the white battery motherboard connector directly out of its port.
Gently peel the battery off of the motherboard.
Use tweezers to disconnect the battery from the motherboard.
Gently lift the rumble motors out of their housings and set them beside the controller.
Gently peel off the battery from the motherboard, with care not to bend or puncture the battery.
Remove the two 7 mm Phillips #1 screws that secure the motherboard.
