跳转到主内容
加入维修社区 - 创建账户
PS4 Dualshock 4 trigger reassembly
浏览量: 5.5万
浏览统计数据:
过去24小时
22
过去 7 天:
139
过去 30 天:
591
总计
55,208
评论: 7
3 comments on steps, 4 guide comments.
Go to guide comments
已完成: 27
27 人已将本指南标记为“已完成”。你会是下一个完成的人吗?
收藏: 1
1 人收藏(并订阅)了本指南。你会是下一个吗?
所需时间: 10分钟
难度: 简单
社区贡献指南
我们社区的一个非常棒的成员制作了本指南。它不是由 iFixit 工作人员创建的。
I decided to create this guide because i got *triggerred* trying to reassemble the PS4 Dualshock 4 Controller
你所需要的
工具
    1. PS4 Dualshock 4 trigger reassembly, Preparing the triggers: 步骤 1 中的图像 1,2 PS4 Dualshock 4 trigger reassembly, Preparing the triggers: 步骤 1 中的图像 2,2
      • Remove these two triggers and springs from the backplate.
      • Find which trigger goes on which side and put the springs in the trigger part facing towards the inside of the controller.
      询问修复机器人
      添加评论
    2. PS4 Dualshock 4 trigger reassembly, Attaching the triggers.: 步骤 2 中的图像 1,2 PS4 Dualshock 4 trigger reassembly, Attaching the triggers.: 步骤 2 中的图像 2,2
      • On these two clips...
      • Push down the trigger until it clicks on both sides.
      • Make sure that the one spring part is inside the rail (marked cyan) and the other outside the whole assembly (green).
      添加评论
    3. PS4 Dualshock 4 trigger reassembly, Connecting the light bar: 步骤 3 中的图像 1,1
      • Connect the light bar cable using your fingers. Make sure it is fully pushed down and that is plugged in the right way.
      询问修复机器人
      添加评论
    4. PS4 Dualshock 4 trigger reassembly, Closing the cover: 步骤 4 中的图像 1,2 PS4 Dualshock 4 trigger reassembly, Closing the cover: 步骤 4 中的图像 2,2
      • close the cover starting from the side of the triggers. Don't worry if it's a bit hard to do so, but be careful so you don't break the plastic between the trigger and the bumper.
      • Push down until it clicks everywhere.
      • Finally, screw in these four screws using a PH0 screwdriver.
      添加评论
终点
取消:我没有完成这个指南。
27等其他人完成本指南。
Devnol
于12/01/18注册
3,032 声望
创作了4篇指南
4指南评论
Thank you so much! I had a ps4 controller that had a broken r2 button and i had gotten a replacement (which is now having battery issues) Today I took the old controller apart… the spring had come out of the rail. That was it!
Dee - 回复 分享
This guide is wrong. The top part spring should be inside the trigger, if you look at the other trigger it’s not exposed.
https://pureplaystation.com/wp-content/u...
Angus Yung - 回复 分享
Thanks for pointing it out. I do not have this controller anymore as it was from a repair job so unfortunately, I cannot correct it. If you or someone else happens to have one and is able to take high-quality pictures I’d be more than grateful to accept your correction.
Devnol - 回复 分享
@angusyung Like you say, swivel one end of the spring into the buttons' cavity and as you line up the placement of the L2/R2 button into the Red marked clips, focus on getting the other end of the spring into the Cyan marked Rail.
dat nekosaka - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 22
过去 7 天: 139
过去 30 天: 591
总计 55,208
