跳转到主内容
PS3 Dual Shock 3 Controler Charging Port Replacement
你所需要的
  1. PS3 Dual Shock 3 Controler Charging Port Replacement, Opening the Controller: 步骤 1 中的图像 1,1
    • Remove the 5 screws on the back of the controller.
    • The back housing of the controller can now be removed.
  2. PS3 Dual Shock 3 Controler Charging Port Replacement, Removing the Battery: 步骤 2 中的图像 1,1
    • Remove battery by unlatching the battery cables from battery connector clip.
  3. PS3 Dual Shock 3 Controler Charging Port Replacement, Freeing the Motherboard: 步骤 3 中的图像 1,1
    • Remove the two screws holding the motherboard to the front controller housing.
    • Next, remove the motherboard assembly from the controller housing. This is done by pressing in the clips on each side of the handle.
    • Freeing the motherboard from the housing will provide better access to the charging port.
  4. PS3 Dual Shock 3 Controler Charging Port Replacement, Preparing the Soldering Station: 步骤 4 中的图像 1,1
    • Prepare your station for the de-soldering of the charging port.
  5. PS3 Dual Shock 3 Controler Charging Port Replacement, Desoldering: 步骤 5 中的图像 1,3 PS3 Dual Shock 3 Controler Charging Port Replacement, Desoldering: 步骤 5 中的图像 2,3 PS3 Dual Shock 3 Controler Charging Port Replacement, Desoldering: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    Desoldering Pump
    $3.99
    • To remove the defective charging port, you will need to de-solder the 9 pins holding the port to the motherboard.
    • First, used the desoldering pump to remove the solder from all 9 pins.
    • Then, use the desoldering wick to remove any excess solder left on the motherboard.
  6. PS3 Dual Shock 3 Controler Charging Port Replacement, Securing New Charging Port: 步骤 6 中的图像 1,1
    • After the charging port is removed, place the new charging port into position.
    • Hold the new port in place by using a clip to keep it from moving.
  7. PS3 Dual Shock 3 Controler Charging Port Replacement, Soldering The New Port: 步骤 7 中的图像 1,2 PS3 Dual Shock 3 Controler Charging Port Replacement, Soldering The New Port: 步骤 7 中的图像 2,2
    • Tin the soldering iron before soldering the connections. This is done by applying a small amount of solder to the tip of the hot iron.
    • Solder the 9 pin connections that connect the charging port to the motherboard.
结论
To reassemble your device, follow instructions 1-3 in reverse order.
17等其他人完成本指南。
Attak
于12/04/17注册
658 声望
撰写一个指南
5指南评论
Shall DualShock3 require other than GND and VBUS for charging only
and does DS3 follow the standards of USB-miniB (eg: Data wires flipping).
Sony does have some fame to sacrifice standards over extra capability delivery.
JanLS - 回复
Would you guys happen to know, if my labeling is correct? I’m going to upgrade to USB-C.
https://imgur.com/a/RL68Yw5
Howling Beats - 回复
Thank you it's really useful, tips,
Alan - 回复
Thanks for this. But now there are four different USB charging ports, how to tell which one of them is suitable? kasynparts eg
kasynlife - 回复
please attak if you still using this platfrom i really need you to help me with a ps3 controller pins
Deyaa Alshapshiri - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 77
过去 30 天: 314
总计 23,392
