简介
用这个向导去移动您的PS3的塑料顶盖
  1. 使用一个撬棒的尖端从PS3的侧面去除黑色橡胶螺丝盖。 这个螺丝盖也许在保修贴纸的下面。贴纸被移除后将会改变外观并且 显示“无效”(移除保修贴纸将使你的设备失去厂家/商家的保修)。
    • 使用一个撬棒的尖端从PS3的侧面去除黑色橡胶螺丝盖。
    • 这个螺丝盖也许在保修贴纸的下面。贴纸被移除后将会改变外观并且 显示“无效”(移除保修贴纸将使你的设备失去厂家/商家的保修)。
  2. 从智能板上取下一个8.5毫米的T10安全Torx螺丝钉。
    • 从智能板上取下一个8.5毫米的T10安全Torx螺丝钉。
  3. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  4. 把智能板拉向硬盘驱动器,然后把它从PS3主体上抬起并且拿下来。 把智能板拉向硬盘驱动器,然后把它从PS3主体上抬起并且拿下来。 把智能板拉向硬盘驱动器,然后把它从PS3主体上抬起并且拿下来。
    • 把智能板拉向硬盘驱动器,然后把它从PS3主体上抬起并且拿下来。
  5. 请注意一定要注意一下松松地放在顶盖上的小金属支架,如果你的机器配备了这样东西的话。
    • 请注意一定要注意一下松松地放在顶盖上的小金属支架,如果你的机器配备了这样东西的话。
    That small metal bracket/socket set up looks completely different in the ps3 I'm working on. Model: CECHK01.
    Any suggestions?
    Marcus - 回复
  6. 去掉这图片中的7个螺丝
    • 去掉这图片中的7个螺丝
    • 6个52毫米的菲利普斯螺丝(十字)
    • 1个30毫米的菲利普斯螺丝(十字)
    2 more smaller screws (don't know what size...small) just below the top middle screw and top right screw (in the picture). Look for the arrows...
    E Goo - 回复
    after you remove the screws, you may have to push a tab to take the cover off if you meet resistance on one side of the cover. Here is a link to a video that explains it, saved me lots of trouble:
    http://youtu.be/jZgekNsRB-A?t=1m54s
    ericksi33 - 回复
    Thanks @ericksi33, this really helped me out.
    hogurt -
    1st attempt, fan loud. Ps3 lasted about 2 wks. 2nd attempt noticed very poor contact between heatsink & cpu,gpu when taking it apart. Research - Found a better way to apply thermal past. I personally disapprove of guide on this. A small bit about the size of a grain of rice in center of cpu is plenty. Clamp the heat sinks back on. Then take it apart & check contact area. Thermal paste should have spread to about the size of a quarter.(more is better. Less then a nickel size is poor contact) possibly weak clamps. Carefully applied pressure onto the cpu & gpu, pressing them into the heatsinks before clamping heatsink clamps on. Achieved greater then quarter sized thermal past spread. Fan silent in comparison & ps3 lasted about a yr. Rarely did I ever hear the fan go to high and get loud after that. About to begin my third fix on this same ps3. One of the first 80g backwards compatible. other then those notes and that this guide was for a different model ps3 (minor differences) I liked this guide. easy to follow.
    brettgomes - 回复
    Although the battery is described as proprietary, it looks like it is the common CR2032 lithium coin battery that is used in calculators and some computers. I haven't had to replace mine but I suspect under the heatshrink cover is a battery holder which will allow the coin battery to be removed and replaced. Then wrap with electrical tape and reinstall.
    RickP - 回复
    I tried this with the heatgun and it ruined my PS3. The CPU and GPU are NOW RUINED!!! It did not work for and made things worst!!! I sent it to a place to get reballed and they said the HEATGUN had overheated my processor and killed them!!! So think twice about doing this. Just because it is already broken, DON'T THINK YOU CAN'T MAKE IT WORST!
    georgehollyoh - 回复
    Why would you try it with a heat gun, no were is it mentioned to do that
    Phillip Pereira -
    There are 2 additional screws to remove , front center and front left , just behind the already marked screws.
    mikentc90 - 回复
    As mentioned and I’ll add so detail too. If you have a model with the card readers there are two more small screws that also need to be removed before moving on to the next step.
    screech - 回复
  7. 从后边缘抬起前盖并且把它旋转到PS3的前部。
    • 从后边缘抬起前盖并且把它旋转到PS3的前部。
    • 拆掉顶盖
    Disconnect the memory card ribbon cable.
    Tobias Stockmann - 回复
    The top would hardly budge on the left back corner and was stuck on the right back corner. There is a plastic hook that needs to be unfastened to lift the top off. It is located in a hole on the top back corner on the right hand side, so the corner straight across the on off button. Just gently push the plastic hook a bit front the rear of the machine with a spudger. It gives easily and the top will be free to lift off after that.
    cornellg - 回复
    Some more details here as well.
    The newer model without SACD support appears to have added that clip to the back right that needs to be pressed to release the top shell.
    If equipped with the card reader you can either have to disconnect the ribbon cable or unclip the reader from the top shell after lifting it up to get finger or tool in there to push clip to side and release reader from top shell. Note: if you failed to remove the card reader screws in the previous step these clips can break.
    screech - 回复
结论
若要重组您的设备,请按此指南倒序安装
40等其他人完成本指南。
特别感谢这些译者︰
85%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
浏览统计数据:
过去的24小时: 3
过去的7天: 28
过去的30天: 160
总计 34,819
