跳转到主内容
PS3主板更换
你所需要的
  1. PS3主板更换, 智能板: 步骤 1 中的图像 1,2 PS3主板更换, 智能板: 步骤 1 中的图像 2,2
    • 使用一个撬棒的尖端从PS3的侧面去除黑色橡胶螺丝盖。
    • 这个螺丝盖也许在保修贴纸的下面。贴纸被移除后将会改变外观并且 显示“无效”(移除保修贴纸将使你的设备失去厂家/商家的保修)。
    Fake repair. Real fault: How to Delid and fix the Yellow Light of Death for good (NEC TOKIN Replacement) https://gbatemp.net/threads/how-to-delid...
    Player - 回复
  2. PS3主板更换: 步骤 2 中的图像 1,1
    • 从智能板上取下一个8.5毫米的T10安全Torx螺丝钉。
    Player - 回复
    I need a tork screw bracket / holder A/E/B/E01- MG and security torx screw for a CECH-AO1 do u guys sell these?
    vuhx - 回复
  3. PS3主板更换: 步骤 3 中的图像 1,3 PS3主板更换: 步骤 3 中的图像 2,3 PS3主板更换: 步骤 3 中的图像 3,3
    • 把智能板拉向硬盘驱动器,然后把它从PS3主体上抬起并且拿下来。
    Player - 回复
  4. PS3主板更换: 步骤 4 中的图像 1,1
    • 请注意一定要注意一下松松地放在顶盖上的小金属支架,如果你的机器配备了这样东西的话。
    That small metal bracket/socket set up looks completely different in the ps3 I'm working on. Model: CECHK01.
    Any suggestions?
    Marcus - 回复
    different in mine too, Model: CECHP01
    Link Adrian - 回复
    mine does not have one at all
    ian.downard01 - 回复
    1How to Delid and fix the Yellow Light of Death for good (NEC TOKIN Replacement) https://gbatemp.net/threads/how-to-delid...
    Player - 回复
    Did not find in my CECHH01
    Philippe Morin - 回复
    I don’t have this bracket, where I can get it ?
    Paul Bidny - 回复
  5. PS3主板更换, 顶盖: 步骤 5 中的图像 1,1
    • 拆卸这图片中的7个螺丝
    • 6个52毫米的菲利普斯螺丝(十字)
    • 1个30毫米的菲利普斯螺丝(十字)
    2 more smaller screws (don't know what size...small) just below the top middle screw and top right screw (in the picture). Look for the arrows...
    E Goo - 回复
    can confirm, might be the backwards compatibles only
    Jordan Giese -
    This usually isn't needed as you can additionally unclip the card reader by pushing the tabs out while lifting the top, They are located at the bottom of the screw holes with the arrows pointing at them
    Kenneth Beerman -
    after you remove the screws, you may have to push a tab to take the cover off if you meet resistance on one side of the cover. Here is a link to a video that explains it, saved me lots of trouble:
    http://youtu.be/jZgekNsRB-A?t=1m54s
    ericksi33 - 回复
    Thanks @ericksi33, this really helped me out.
    hogurt -
    1st attempt, fan loud. Ps3 lasted about 2 wks. 2nd attempt noticed very poor contact between heatsink & cpu,gpu when taking it apart. Research - Found a better way to apply thermal past. I personally disapprove of guide on this. A small bit about the size of a grain of rice in center of cpu is plenty. Clamp the heat sinks back on. Then take it apart & check contact area. Thermal paste should have spread to about the size of a quarter.(more is better. Less then a nickel size is poor contact) possibly weak clamps. Carefully applied pressure onto the cpu & gpu, pressing them into the heatsinks before clamping heatsink clamps on. Achieved greater then quarter sized thermal past spread. Fan silent in comparison & ps3 lasted about a yr. Rarely did I ever hear the fan go to high and get loud after that. About to begin my third fix on this same ps3. One of the first 80g backwards compatible. other then those notes and that this guide was for a different model ps3 (minor differences) I liked this guide. easy to follow.
    brettgomes - 回复
    Although the battery is described as proprietary, it looks like it is the common CR2032 lithium coin battery that is used in calculators and some computers. I haven't had to replace mine but I suspect under the heatshrink cover is a battery holder which will allow the coin battery to be removed and replaced. Then wrap with electrical tape and reinstall.
    RickP - 回复
    I tried this with the heatgun and it ruined my PS3. The CPU and GPU are NOW RUINED!!! It did not work for and made things worst!!! I sent it to a place to get reballed and they said the HEATGUN had overheated my processor and killed them!!! So think twice about doing this. Just because it is already broken, DON'T THINK YOU CAN'T MAKE IT WORST!
    georgehollyoh - 回复
    Why would you try it with a heat gun, no were is it mentioned to do that
    Phillip Pereira -
    There are 2 additional screws to remove , front center and front left , just behind the already marked screws.
    mikentc90 - 回复
    As mentioned and I’ll add so detail too. If you have a model with the card readers there are two more small screws that also need to be removed before moving on to the next step.
    screech - 回复
    2How to Delid and fix the Yellow Light of Death for good (NEC TOKIN Replacement) https://gbatemp.net/threads/how-to-delid...
    Player - 回复
    I felt more comfortable with #2 screwdrivers.
    Philippe Morin - 回复
  6. PS3主板更换: 步骤 6 中的图像 1,1
    • 从后边缘抬起顶盖并且把它旋转到PS3的前部。
    • 拆掉顶盖
    Disconnect the memory card ribbon cable.
    Tobias Stockmann - 回复
    The top would hardly budge on the left back corner and was stuck on the right back corner. There is a plastic hook that needs to be unfastened to lift the top off. It is located in a hole on the top back corner on the right hand side, so the corner straight across the on off button. Just gently push the plastic hook a bit front the rear of the machine with a spudger. It gives easily and the top will be free to lift off after that.
    cornellg - 回复
    I can confirm on CECHH01.
    Philippe Morin -
    Some more details here as well.
    The newer model without SACD support appears to have added that clip to the back right that needs to be pressed to release the top shell.
    If equipped with the card reader you can either have to disconnect the ribbon cable or unclip the reader from the top shell after lifting it up to get finger or tool in there to push clip to side and release reader from top shell. Note: if you failed to remove the card reader screws in the previous step these clips can break.
    screech - 回复
    The original 60GB with the CF card reader on the front has a button protruding out. This will make it difficult to remove the top. You need to unscrew the memory card reader so it can come out easily.
    Brian Caines - 回复
    Wow, this needs more attention. This isn't explained in any disassembly guide I've seen. You also need to be cognizant of the card reader cable when you're lifting off the lid.
    SolidSonicTH -
    I didn't have trouble during disassembly, but reassembly was tough. I loosened the card reader screws by 1 turn and used a small gauge wire to lasso the button and ran it through the CF hole.
    Carl Garner -
  7. PS3主板更换, 蓝光驱动器: 步骤 7 中的图像 1,1
    • 从主板断开蓝光的电缆
    • 如图,将插头垂直拉出插座
    I would add… “Be careful taking these type of connectors apart” …. its easy to pull the entire thing off the motherboard and rip pads !
    The pulled pads can be replaced but its extra work you don’t need :-) and requires equipment and skill to do and cold require jumper wires.
    asears - 回复
    Pull the cables gently, the plug will come out of the socket. The plug is encased by the socket.
    A K - 回复
    That’s also what I did.
    Philippe Morin -
    My PS3 is the CECHL01 and I had to remove the PSU to get to the disk drive ribbon cable.
    Benjamin Burden - 回复
    I mistakenly ripped the whole thing out... I do not know where to begin on repairing it.
    Tom Gillis - 回复
  8. PS3主板更换: 步骤 8 中的图像 1,1
    • 从最靠近电源的边缘抬起蓝光驱动器,并且把它从机箱旋转到足够接近带状电缆。
  9. PS3主板更换: 步骤 9 中的图像 1,3 PS3主板更换: 步骤 9 中的图像 2,3 PS3主板更换: 步骤 9 中的图像 3,3
    • 用你的指甲在蓝光带状电缆插座上翻转固定襟翼。
    • 确保翘起襟翼而不是插座本身。
    • 把带状电缆从插座上拔出。
    • 从PS3上取下蓝光光驱。
    • 如果更换新的蓝光驱动器,请将电源移到您新的驱动器上。
    Not all systems look like this, some have tape instead of the flap.
    gatewaynomad - 回复
    Every system that I have seen has had the ZIF connector, while some had tape over the connection as well. If your connectors are taped, be sure to remove the tape, then proceed with undoing the ZIF connector.
    Brett Hartt -
    The version 2 systems baseboard PCB started switching to the new narrow 24 pin ZIF header/ribbon and Blu-Ray drive connection.
    You should not attempt to detach the taped ribbon cable from the drive end first as described above for the older wide 60 pin ribbons. You must remove the drive and ribbon as one unit to protect the fragile ZIF sockets.
    The slimmer fragile ribbon is taped to the drive housing to afford a more secure ZIF connection. The opposite base connection is slightly under the PSU.
    continued
    shadetree - 回复
    From continued
    One should firstly remove the PSU: Disconnect the drive power cable as described above. Unscrew the 5 (3-P1 2-P2) PSU mounting screws. Now leaving the power cables attached, lift the PSU off the power baseboard PCB pins and move over slightly to access the baseboard drive cable end ZIF. Release the ZIF latch and slide the entire (drive and ribbon) strait away from the baseboard ZIF to disconnect.
    After the complete drive/ribbon removal, you can carefully remove the restraining tape on the bottom of the drive to release the ribbon ZIF, then remove the 24 pin ribbon from the drive logic PCB.
    Install in reverse order making sure to add new tape to secure the ribbon to the drive.
    shadetree - 回复
    I needed to remove the PSO completely to reach the baseboard drive cable end ZIF. To do that disconnect the power and data (I assume) cables and then pull the unit straight up. To longish prongs are heading straight up into it from the baseboard and it is a bit tight, so gently pull until it's clear.
    cornellg -
    If you are replacing the Blu-ray drive, you must use the same daughterboard that came with your PlayStation 3. The daughterboard is paired to the motherboard, and the Blu-ray drive will not work with a different board. -------------- I understand however my daughterboard is not on the bottom of the blu-ray drive it must be on the inside. Is there any advice out there on how I go about doing this as I am not sure what I am doing???? If someone could post a link or any tips it would be greatly appreciated.
    jimmy - 回复
    When I received my new drive there was a sheet that said you could keep the old boards but you have to 'flash' them with the ps3's digital information. Currently trying to figure out how.....
    Cheffy -
    My CECHH01 has its blu-ray drive encased in a shield plate. Only one ribbon cable is visible. (The one we have to disconnect). Mine had some tape over it.
    Also, I used a spudger instead of my nails.
    Philippe Morin - 回复
  10. PS3主板更换, 主板: 步骤 10 中的图像 1,1
    • 将控制板上的带状电缆直接从主板上的插座中拔出。
    Some PS3 versions do not have a separate control board, since the buttons and LEDS are located on the motherboard (for example, in my PS3 model CECHG04). In this case steps 10, 11 and 13 are not applicable.
    markp - 回复
    This is also true for my CECHH01. ?‍♂️
    Philippe Morin -
  11. PS3主板更换: 步骤 11 中的图像 1,2 PS3主板更换: 步骤 11 中的图像 2,2
    • 拆掉两个12毫米的Phillips螺丝,把控制板固定到底部外壳。
    • 从PS3上拆掉控制板以及它的附属电缆。
  12. PS3主板更换: 步骤 12 中的图像 1,1
    • 拆掉图中8个螺丝把主板组件固定到较低外壳上。
    • 7个12毫米菲利普斯螺丝
    • 1个30毫米的菲利普斯螺丝
    On my machine (fat PS3 with no card reader and 2 USB ports), there is no upper right screw to remove.
    alansliu - 回复
    That 30mm screw is the one lower down under the power cable, not the higher up one with the embossed arrow pointing at it.
    James Beegle - 回复
    Hey guys, that red and orange you are using are not at all identifiable as separate colors to some of us with colorblindness. I had to get my buddy to tell me which one was orange and which was red. In the future, it would be most helpful if you stuck to contrasting colors. Great guide, thanks for making it!
    Aksel Barnes - 回复
    Step 17 helps with the 30 mm upper left screw
    joshuavivelavida - 回复
    For any further vision impaired people trying to follow along, the single 30mm screw is in the top left of the image.
    James Beegle - 回复
    Voting up the comments about the orange v red colors on the images, I'm surprised that such a simple edit has not been done over the past three+ years.
    Palfrus Wyrmrest - 回复
  13. PS3主板更换: 步骤 13 中的图像 1,1
    • 拆下主板支架。
  14. PS3主板更换: 步骤 14 中的图像 1,2 PS3主板更换: 步骤 14 中的图像 2,2
    • 用撬棍的平底撬起硬盘驱动器支架使其远离低的一端。
    • 拆下硬盘盖。
  15. PS3主板更换: 步骤 15 中的图像 1,1
    • 从底板上抬起主板组件。
    My Ps3 was a little different..
    The rear backing plate is connected to the fan shroud beneath the unit that is screwed into the bottom of the case.. And these large chrome pieces attatched to the fan were stuck to the tray that the board is on. Came a part pretty rough, guessing the ps3 got so hot it turned the grease into glue lol
    intotec239 - 回复
    If you already suspect you may have a slightly different PS3 model to the one pictured here STOP RIGHT NOW! Do not try and lift the motherboard off the lower casing if it is not coming easily. On mine, the cooling fan and heat sinks have extra screws directly into the lower plastic case and you will not be able to lift the motherboard out until after you have done Step 27. So skip this step, continue through the guide, skip 18-23 (you probably don't have a memory card reader). After unscrewing the 4 screws in Step 27, pull hard to separate the motherboard from the heat sinks (they will be attached with thermal paste like a glue). Only then will you be able to access the screws to separate the large fan and heat sinks from the plastic lower case.
    Incidentally I totally smashed mine trying to get the lower case off here at step 15 - I broke the screws off, warped the metal on the heat sink and snapped pieces of plastic. But I continued and did the heat gun stuff and it still actually worked!!
    Fat Albert - 回复
  16. PS3主板更换, 电源接口: 步骤 16 中的图像 1,1
    • 移除将接地皮带固定在底壳上的7.7mm十字螺丝。
    On my PS3 the ground wire(green/yellow) was actually routed under the bolt for the power supply, so I had to remove the power supply before I could removed the AC inlet
    jorgebustos2254 - 回复
  17. PS3主板更换: 步骤 17 中的图像 1,2 PS3主板更换: 步骤 17 中的图像 2,2
    • 将交流电源电缆稍微拉离后盖,以创造间隙来找到交流电源连接头。
    • 在按下其锁定机构的同时,将交流电源连接头拔出电源插座。
  18. PS3主板更换: 步骤 18 中的图像 1,1
    • 从后盖的底部拉出交流电源插座,查看可能被卡住的任何电缆。
    I had to loosen the two screws on the perforated cover to get the ground wire out.
    asciimo - 回复
    Had to remove 2 screws (the top 2 screws marked in step 25) to get the ground cable out.
    deuxphoria - 回复
    Like @asciimo and @deuxphoria, I had to loosen the same two screws to get the ground wire out. When you're putting the PS3 back together and you're doing the steps in reverse, it helps to leave those two screws unscrewed during Step 25 and wait until you put the AC inlet back in Step 18.
    hogurt - 回复
    You can put the 2 screws back in step 25, just put the AC Outlet before you put in the back plate. (Do Step 18 before step 19 when you are going in reverse)
    xaviertaylor - 回复
  19. PS3主板更换, 后面板: 步骤 19 中的图像 1,2 PS3主板更换, 后面板: 步骤 19 中的图像 2,2
    • 轻轻地将后面板拉离逻辑板组件。 使用撬棒扁平的一端来松开后面板顶部边缘处的夹子。
    If going in reverse do this step after step 18, otherwise you will have hard time getting the earth cable routed.
    xaviertaylor - 回复
  20. PS3主板更换: 步骤 20 中的图像 1,1
    • 从逻辑板组件上移走后面板。
  21. PS3主板更换, 散热器: 步骤 21 中的图像 1,2 PS3主板更换, 散热器: 步骤 21 中的图像 2,2
    • 将风扇电缆从塑料支架上拆下来。
    • 断开风扇与主板的连接。
    • 将连接器向上拉出并从插座中拔出。
  22. PS3主板更换: 步骤 22 中的图像 1,1
    • 移除将记忆卡读卡器固定在外壳上的2颗9mm十字螺丝。
    Only the very first release of the PS3 used to have the memory card reader. Most recent models do not have it (such as my PS3 model CECHG04). In this case just skip steps 22 and 23.
    markp - 回复
    Also, these screws should be removed in step 5 to prevent breaking the clips that secure the card reader to the top shell.
    screech - 回复
  23. PS3主板更换: 步骤 23 中的图像 1,2 PS3主板更换: 步骤 23 中的图像 2,2
    • 将记忆卡读卡器往PS3外提,直到能够看到排线为止。
    • 翻转记忆卡读卡器带状电缆插座上的固定挡板。
    • 确保你正在撬起挡板,而不是插座本身。
    • 将带状电缆从其插座中拉出并取出记忆卡读卡器。
    I have a CECHA01 and the card reader is attached to the top cover. Per comments at step 5, the 2 screws mentioned at step 22 are removed at step 5. The ribbon cable mentioned here in step 23 should be removed at step 5.
    Jon Tyre - 回复
    If leaving card reader attached to top shell this step should be part of step 6.
    screech - 回复
  24. PS3主板更换: 步骤 24 中的图像 1,1
    • 从散热器前面断开交流电输入线缆。
    • 向PS3前面拉动插头。
  25. PS3主板更换: 步骤 25 中的图像 1,1
    • 移除将电源与机壳固定的5颗9mm 十字螺丝。
  26. PS3主板更换: 步骤 26 中的图像 1,1
    • 从电源前面的边角处提起来松开其与主板之间的两个连接点。
    • 移除电源
    I had a small black wire taped to the side of my power supply. If you have this - remember to remove the tape, first, or you run the risk of pulling the wire out.
    Oliver Clare - 回复
  27. PS3主板更换: 步骤 27 中的图像 1,1
    • 移除将散热器固定到主板的4颗16.5mm 肩状十字螺丝。
    • 移除刚卸下螺丝底下的两个支架。
  28. PS3主板更换: 步骤 28 中的图像 1,1
    • 从散热器上提起主板组件。
    • 散热片仍然可以通过散热膏保持在适当位置。 如果是这种情况,请轻轻地将散热器从主板外壳上撬开。 确保不要弯曲散热器上的铜管。
    • 重新安装散热器时,请务必使用新的散热膏。
    • 之前从来没有涂过散热膏? 我们的散热膏指南使其变得容易。
    • 如果您正在关注YLOD维修指南,请继续关注哪里应用更换散热膏。
    so do we apply arctic silver 5 thermal paste to the heat sink pads that attach to the CPU GPU,Or do we only apply thermal paste to the chips /pads CPU GPU ?
    David - 回复
    In some PS3 versions, such as my PS3 model CECHG04, the heat sink is attached to the lower half of the motherboard shield, so in order to remove the motherboard you have to lift the top cover and detach the motherboard from the heat sink.
    markp - 回复
    Yeah, on mine (which is the very first revision of the PS3), you have to add a SUPER heavy amount of thermal paste, for it to even make contact. Odd.
    Christopher - 回复
    Can someone confirm what material the heatsink is made of for those wanting to apply liquid metal (I'm sure as !&&* not taking the risk) but might be of interest to others…
    Jjj - 回复
  29. PS3主板更换, 主板: 步骤 29 中的图像 1,2 PS3主板更换, 主板: 步骤 29 中的图像 2,2
    • 掀开蓝边带缆插口处的挡板。
    • 要确保是你自己掀开的这块挡板,而不是带缆插口自身掀开的。
    • 拔出蓝边带缆。
    On my 60GB model, the Blu-ray ribbon cable was very easy to disconnect, but a real pain to re-connect. It's not as easy as pushing the black fap down to secure the ribbon. This YouTube video helped enormously: https://www.youtube.com/watch?v=Zn1pMLGH....
    hogurt - 回复
    To follow what hogurt said, you have to push down and back a bit with the clip. (Watch the video, it’s good). If the clip bounces right back with resistance, STOP and don’t keep pushing or you will break the clip.
    Steven Vallarian -
  30. PS3主板更换: 步骤 30 中的图像 1,2 PS3主板更换: 步骤 30 中的图像 2,2
    • 把连接储存卡读卡器的连接线上盖板取下,然后取下连接线。
  31. PS3主板更换: 步骤 31 中的图像 1,2 PS3主板更换: 步骤 31 中的图像 2,2
    • 揭开Wi-Fi/蓝牙天线保护盖。
    • 将Wi-Fi/蓝牙天线拔出来。
    Missing a step here where you actually remove the cw1-100 board. 4 screws and it comes out.
    Steven Vallarian - 回复
    What does the black cable?
    Robert Brown - 回复
    This cable is the antena cable for WiFi and Bluetooth. This cable is used to conduct electric signal between the antena and the wireless network chip integrated to the device's motherboard.
    Brendan -
  32. PS3主板更换: 步骤 32 中的图像 1,1
    • 从主板上拔出交流电插座,搁置在一旁。
    • 直直地拔出连接线,插座完全脱离主板。
  33. PS3主板更换: 步骤 33 中的图像 1,1
    • 从主板上断开PRAM电池的连接。
    • PRAM插座非常细致,有可能会从主板上断掉。如果可能,拔出来的时候按住插头。
    In the most recent PS3 versions, the PRAM battery is located on the motherboard: remove it before performing the reflow and don’t forget to put it back before starting the re-assembly.
    markp - 回复
  34. PS3主板更换: 步骤 34 中的图像 1,3 PS3主板更换: 步骤 34 中的图像 2,3 PS3主板更换: 步骤 34 中的图像 3,3
    • 逆时针转PRAM电池,从主板上移除。
    It is quite hard to rotate counterclockwise, but by rotating it slides out, no pulling up is needed. Hard to do by hand, but much easier if you use some flat nose pliers.
    jerseyzangel - 回复
    Same here. Even with pliers, my PRAM battery was incredibly difficult to remove. When it did finally come loose, part of the black plastic that keeps it secure broke off for me. The whole thing is loose now when I put it back, but still stays in place.
    hogurt -
    Worked. Took 3 hours to complete.
    ****NOTES that weren't mentioned here****
    1. Heat Gun on processors = zigzag from top left to bottom right - then circle back up to the top left. repeat.
    2. No thermal pads available in your area?
    I used the same thermal pads that came with the PS3
    3. No T-10 security screw driver?
    I broke the very first step - I didn't have a t10 security driver and jsut figured I would risk breaking the cover a bit by pulling it straight up - popped right off - then broke the stupid screw right off of it.
    4. took 15 minutes to find things to ensure the motherboard we perfectly level.
    5. I let the Motherboard sit for exactly 17 minutes and then applied Arctic silver.
    6. No Screwtray ?
    I used a piece of duct tape, sorta flipped it around so it was a sticky pad to grab all the screws and not let them get unorganized.
    I hope I remember to report back how long the system runs until it dies again, which I hear happens fairly quickly after this type of operation.
    Good Luck.
    infinitist - 回复
    mine has a small round tab on the PRAM battery housing that locks it in place. i had to slip the flat end of the spudger between the PRAM battery housing and motherboard cover to release the tab. after that it rotated quite easily with no need for pliers or anything.
    jcelkay - 回复
    I didn't handle the motherboard correctly and Mistakenly ripped off the wires off PRAM! How can I fix it?
    Renata Szczech - 回复
    Like jcelkay said, I just needed to use the back end of the spudger on the non-cable side of the PRAM and sort of finesse it a bit. When I did this it became much easier. Getting it back on I had to do the same thing.
    Naomi Young - 回复
  35. PS3主板更换: 步骤 35 中的图像 1,1
    • 移除固定硬盘的蓝色8毫米十字螺丝。
  36. PS3主板更换: 步骤 36 中的图像 1,3 PS3主板更换: 步骤 36 中的图像 2,3 PS3主板更换: 步骤 36 中的图像 3,3
    • 向主板方向推一下硬盘架。
    • 从主板上移除硬盘。
  37. PS3主板更换: 步骤 37 中的图像 1,1
    • 移除两个固定着硬盘插座底座的3.7毫米#0大小十字螺丝。
    The fixit kit doesn’t come with a Phillips head small enough?
    William Chance - 回复
    I am stuck on step 37. Those screws are REALLY in there and the #1 Phillips is stripping the heads. What are my options/what do you recommend? How have other folks been successful?
    Eric Riley - 回复
    @ericriley85649 we have a guide on how to remove a stripped screw, I hope that helps: 如何卸下滑丝的螺丝
    Sandra Hiller -
  38. PS3主板更换: 步骤 38 中的图像 1,1
    • 一起拆卸固定主板的两个8.3毫米# 0飞利普螺丝。
    On step 38 what is the thread count on the 8.3mm screws? I'm missing and need to know before I go out to the store.
    ericambrose32 - 回复
  39. PS3主板更换: 步骤 39 中的图像 1,1
    • 小心地对待穿过主板盖顶上的孔的无线/蓝牙电缆。
    • 拆下主板盖。
    This step is tricky, because the thermal paste from the chips could act as a ‘semi glue’, so you have to softly try for some minutes…
    Roger - 回复
    Also, if I understand correctly, once this step is done, you pretty much NEED to have replacement pads at home, because I the old ones might be wrecked. :P Is it true?
    Philippe Morin -
  40. PS3主板更换: 步骤 40 中的图像 1,1
    • 将主板从主板盖上拆下。
  41. PS3主板更换: 步骤 41 中的图像 1,2 PS3主板更换: 步骤 41 中的图像 2,2
    • 翻开挡在Wi-Fi /蓝牙排线间的插座盖。
    • 拆除Wi-Fi /蓝牙与主板的排线
    • 保留主板。
结论
以相反的顺序执行这些步骤来还原PS3
81等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
4条评论
Just fixed my YLOD last nite and it works like a charm! best guide on the internet, and it was free! i bought the kit here and it has everything you need minus the gunk off. One thing I'd like to see is how to organize all the screws... I had 2 left over after reassembling the unit. it'll also be nice if the guide showed you how to put certain parts back on (back case, top case units).
It took me a total of 3 hours to do. Not bad considering I don't tear things apart for a living.
other than that, the guide and kit are awesome!
Mike Cha - 回复
Just fixed my PS3 Fat. It's the only one that plays PS2 games so it was hard to part with. Instructions were easy to follow. However, I didn't replace the pads on the chips. PS3 is working beautifully again and the fan is much quieter now. I kept forgetting screws and the WIFI cable so I had to take it apart at least a few more times. Now I can take apart and reassemble the PS3 in my sleep.
Charles - 回复
I need schematics board or service manual ps3 fat CECHGxx
sandy - 回复
Display not showing and red light blinking
Led - 回复
添加评论
浏览统计数据:
过去 24 小时: 13
过去 7 天: 125
过去 30 天: 528
总计 174,063
