跳转到主内容
加入维修社区 - 创建账户
PS Vita Slim Battery Replacement
你所需要的
  1. PS Vita Slim Battery  Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Please make sure the system is completely powered off and all SD storage cards are removed before starting the removal process
    • All 6.35mm screws were removed using a J00 bit from the iFixit pro toolkit.
    • There are four screws on the back of the device, remove them as shown.
    添加评论
  2. PS Vita Slim Battery  Replacement: 步骤 2 中的图像 1,2 PS Vita Slim Battery  Replacement: 步骤 2 中的图像 2,2
    • There are two screws on the bottom, near the charging port, remove them using the J00 screwdriver on the 6.35mm screws from the iFixit pro toolkit.
    • Finally, remove the top screw under the dust cover using the J00 screwdriver on the 6.35mm screws from the iFixit pro toolkit.
    询问修复机器人
    添加评论
  3. PS Vita Slim Battery  Replacement: 步骤 3 中的图像 1,3 PS Vita Slim Battery  Replacement: 步骤 3 中的图像 2,3 PS Vita Slim Battery  Replacement: 步骤 3 中的图像 3,3
    • The next step will require the opening tool.
    • Please carefully separate the back from the front completely. You will need to disconnect the small ribbon cable on the inside before completely removing the back. Otherwise you may end up hurting the ribbons on the inside.
    • While separating the back, carefully pry all the way around the back. You will hear popping noises while going around and this is a good sign.
    • Upon removing the back panel you will need to slowly and carefully remove the ribbons connecting the hardware to access the needed parts to be repaired.
    添加评论
  4. PS Vita Slim Battery  Replacement: 步骤 4 中的图像 1,1
    • Once the ribbons have been removed, then the back is fully removed and you can access the hardware within.
    添加评论
  5. PS Vita Slim Battery  Replacement, Battery: 步骤 5 中的图像 1,3 PS Vita Slim Battery  Replacement, Battery: 步骤 5 中的图像 2,3 PS Vita Slim Battery  Replacement, Battery: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    Spudger
    $3.99
    • The battery should be very visible at this point in the guide.
    • Using the spudger, carefully pry the battery connector upwards out of the socket. Do not fully remove the battery yet.
    • Now using the tweezers, carefully remove the ribbon connecting the battery from the hardware.
    • The battery isn't held in by anything, so it can fall out of the case if turned upside down.
    询问修复机器人
    添加评论
  6. PS Vita Slim Battery  Replacement: 步骤 6 中的图像 1,1
    • Now the battery is removable and the process should be complete. You should be free to do what is needed.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
12等其他人完成本指南。
4指南评论
Whilst tearing down my PCH-2016 model PS Vita Slim I have noticed that there is also a screw in the cartridge area that needs to be removed to remove the back panel.
Jack Wallis - 回复 分享
The touchpad cable isn't able to be re-attached if you do this so your vita just ends up becoming permanently crippled. DO NOT FOLLOW THIS GUIDE.
polocatfan - 回复 分享
@polocatfan yes it can? just needs some good technique
Darryl C - 回复 分享
@squirrelmuncher can 100% confirm it's impossible. I tried for hours.
polocatfan - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 26
过去 7 天: 218
过去 30 天: 861
总计 46,632
