此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
简介
转到步骤 1 ↓注意::: 拆解设备可能会导致保修失效,请谨慎操作;如果可能,请优先考虑由厂商进行维修。本指南旨在帮助你更换 PS Vita Slim 上的按钮。如果按钮出现粘滞、磨损或损坏,你可能需要进行此操作。更换按钮的步骤应当比较简单。只要你从容不迫并小心操作设备,就不会有什么问题。
你所需要的
要重新组装设备,请按相反顺序执行这些说明。
5等其他人完成本指南。
3指南评论
the ps button doesn't work, i have replaced the left d pad but it still doesn't work, where is the possible damage?
Likely the board. Same thing happened to me, but with the square button. Button replacement didn't work and I had to replace the right board.
Josh Beoulve - 回复 分享
Slight correction on Step 8. This should be a J000, not 00. You'll end up stripping the screws if you're not careful.
