当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Take note of the wiring before desoldering the wires.
Begin desoldering the pickup wires.
Take care when soldering, as the tip is very hot.
Refer to the wiring arrangements you took note of as well as the wiring manual that came with your new pickups.
Run the new pickups back through the guitar with the wires guided through the back plate.
Carefully begin soldering the new pickup wires back together.
This is a good opportunity to clean the guitar.
Begin restringing the guitar with new strings of your preference.
Using a string/wire cutter and cut excess strings from tuners.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
