跳转到主内容
PRS Guitar Pickups Replacement
你所需要的
  1. PRS Guitar Pickups Replacement, Pickups: 步骤 1 中的图像 1,2 PRS Guitar Pickups Replacement, Pickups: 步骤 1 中的图像 2,2
    • Loosen all of the strings until they can be pulled out of the tuners.
    • Pull the strings through the bridge and out of the back side of the guitar.
  2. PRS Guitar Pickups Replacement: 步骤 2 中的图像 1,2 PRS Guitar Pickups Replacement: 步骤 2 中的图像 2,2
    • Using a Phillips head screwdriver, unscrew the back plate, revealing the pickup wiring.
  3. PRS Guitar Pickups Replacement: 步骤 3 中的图像 1,1
    • Take note of the wiring before desoldering the wires.
    • Begin desoldering the pickup wires.
    • Take care when soldering, as the tip is very hot.
  4. PRS Guitar Pickups Replacement: 步骤 4 中的图像 1,2 PRS Guitar Pickups Replacement: 步骤 4 中的图像 2,2
    • Turn the guitar face up and unscrew both of the pickups.
    • Take the pickups out of the guitar.
  5. PRS Guitar Pickups Replacement: 步骤 5 中的图像 1,2 PRS Guitar Pickups Replacement: 步骤 5 中的图像 2,2
    • Refer to the wiring arrangements you took note of as well as the wiring manual that came with your new pickups.
    • Run the new pickups back through the guitar with the wires guided through the back plate.
    • Carefully begin soldering the new pickup wires back together.
  6. PRS Guitar Pickups Replacement: 步骤 6 中的图像 1,1
    • This is a good opportunity to clean the guitar.
    • Begin restringing the guitar with new strings of your preference.
    • Using a string/wire cutter and cut excess strings from tuners.
终点
Nathan Kevil
于02/25/21注册
141 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 1,015
