跳转到主内容
简介
In this guide, we will show you how to replace pickups in a Paul Reed Smith, also known as a PRS electric guitar. This guide covers basic steps on removing strings, taking out old pickups, and installing new ones. It is geared towards any guitar player who is experiencing problems with their pickups and needs replacements.
Before you begin, make sure you have the required tools listed for this guide. It may be good to know how to work a soldering iron before replacing your pickups as well. Make sure you have extra strings tucked away because you will need to remove and replace the old ones. Lastly, make sure that you have a nice space with a towel to put the guitar on to avoid any scratches while performing this replacement.
  1. Loosen all of the strings until they can be pulled out of the tuners. Pull the strings through the bridge and out of the back side of the guitar.
    • Loosen all of the strings until they can be pulled out of the tuners.
    • Pull the strings through the bridge and out of the back side of the guitar.
  2. Using a Phillips head screwdriver, unscrew the back plate, revealing the pickup wiring. Using a Phillips head screwdriver, unscrew the back plate, revealing the pickup wiring.
    • Using a Phillips head screwdriver, unscrew the back plate, revealing the pickup wiring.
  3. Take note of the wiring before desoldering the wires.
    • Take note of the wiring before desoldering the wires.
    • Begin desoldering the pickup wires.
    • Take care when soldering, as the tip is very hot.
  4. Turn the guitar face up and unscrew both of the pickups. Take the pickups out of the guitar.
    • Turn the guitar face up and unscrew both of the pickups.
    • Take the pickups out of the guitar.
  5. Refer to the wiring arrangements you took note of as well as the wiring manual that came with your new pickups. Run the new pickups back through the guitar with the wires guided through the back plate.
    • Refer to the wiring arrangements you took note of as well as the wiring manual that came with your new pickups.
    • Run the new pickups back through the guitar with the wires guided through the back plate.
    • Carefully begin soldering the new pickup wires back together.
  6. This is a good opportunity to clean the guitar.
    • This is a good opportunity to clean the guitar.
    • Begin restringing the guitar with new strings of your preference.
    • Using a string/wire cutter and cut excess strings from tuners.
终点
Nathan Kevil
于2021年02月25日注册
141 信誉积分
撰写一个指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 2
总计 76
