跳转到主内容
PDP Victrix Pro BFG Battery and Trigger Replacement
你所需要的
  1. PDP Victrix Pro BFG Battery and Trigger Replacement, Battery and Trigger: 步骤 1 中的图像 1,1
    • Use the purple Module Swap Tool that comes with the device to remove the 4 hex screws.
    • Remove the joystick/button modules from the controller.
  2. PDP Victrix Pro BFG Battery and Trigger Replacement: 步骤 2 中的图像 1,1
    • Remove the screws from each of the module compartments using a PH0 or J1 bit.
  3. PDP Victrix Pro BFG Battery and Trigger Replacement: 步骤 3 中的图像 1,2 PDP Victrix Pro BFG Battery and Trigger Replacement: 步骤 3 中的图像 2,2
    • Using the iFixit opening tool, gently pry open the two side grips.
    • Using a PH0 or J1 screwdriver bit with a 4mm diameter or less, remove the screws located in the bottom outside corners.
  4. PDP Victrix Pro BFG Battery and Trigger Replacement: 步骤 4 中的图像 1,1
    • Flip the controller to the other side so the label on the bottom is facing upwards.
    • On the label, there is a circular icon; this shows the location of a single screw.
    • Using the same PH0 or J1 screwdriver bit from the previous steps, remove the screw.
  5. PDP Victrix Pro BFG Battery and Trigger Replacement: 步骤 5 中的图像 1,1
    • Flip the controller so the charging port of the controller is facing you.
    • Using a spudger, carefully pry open the front component.
  6. PDP Victrix Pro BFG Battery and Trigger Replacement: 步骤 6 中的图像 1,1
    • Flip the controller so it is upside-down, but the charging port is still facing you.
    • In the center of the now exposed part, there will be a hidden silver screw.
    • Use the flexible piece attached to the screwdriver to remove this screw.
    • Now that everything is loosened, gently pry open the controller along the grooves.
  7. PDP Victrix Pro BFG Battery and Trigger Replacement: 步骤 7 中的图像 1,1
    • Using the screwdriver tool with a smaller head, remove the three screws from each trigger.
    • Remove the triggers.
  8. PDP Victrix Pro BFG Battery and Trigger Replacement: 步骤 8 中的图像 1,1
    • Using the screwdriver, remove the two screws in the bottom two corners.
    • Using the halberd spudger, carefully pry the circuit board open.
  9. PDP Victrix Pro BFG Battery and Trigger Replacement: 步骤 9 中的图像 1,1
    • To remove the batteries, use a pair of tweezers to carefully unplug the batteries from the circuit board.
结论
4等其他人完成本指南。
ryanmorabito
于03/20/24注册
260 声望
撰写一个指南
团队
UMass Dartmouth, Team 1-1, Santin Spring 2024 UMass Dartmouth, Team 1-1, Santin Spring 2024 的会员
UMASSD-SANTIN-S24S1G1
3 名成员
创作了3篇指南
4指南评论
Only guide I could find to get this controller apart for my son. Now have to find someone to resolder the USB c port.
Matthew Lash - 回复
R2 and L2 no response, the board location for button?
Terry - 回复
if my remote doesn’t turn on or charge should I change the battery or just throw it away?
Nerdy mom - 回复
How much and how can I buy the battery's?
Dino - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 76
过去 30 天: 277
总计 4,890
