跳转到主内容
PDP Rematch Joystick Cover Replacement
你所需要的
  1. PDP Rematch Joystick Cover Replacement, Faceplate: 步骤 1 中的图像 1,2 PDP Rematch Joystick Cover Replacement, Faceplate: 步骤 1 中的图像 2,2
    • Grip one side of the controller firmly.
    • Insert an opening pick into the crease between the faceplate and the body of the controller.
    • Once the pick creates a gap in the crease, gently insert another pick into a different section of the crease.
    • Carefully move the picks along the controller's crease line until you hear a popping sound.
    • Gently lift off the faceplate by hand.
  2. PDP Rematch Joystick Cover Replacement: 步骤 2 中的图像 1,2 PDP Rematch Joystick Cover Replacement: 步骤 2 中的图像 2,2
    • Remove the 8 mm screws from the hard cover using a JIS #00 screwdriver.
    • Since the screws have been removed, avoid shaking or moving your controller too much to prevent other buttons from falling out.
  3. PDP Rematch Joystick Cover Replacement: 步骤 3 中的图像 1,2 PDP Rematch Joystick Cover Replacement: 步骤 3 中的图像 2,2
    • Gently lift off the hard cover with your hand; it should not need much force.
  4. PDP Rematch Joystick Cover Replacement, Joystick Cover: 步骤 4 中的图像 1,1
    • The action buttons and silicone pad are loose and may fall out of the controller.
  5. PDP Rematch Joystick Cover Replacement: 步骤 5 中的图像 1,2 PDP Rematch Joystick Cover Replacement: 步骤 5 中的图像 2,2
    • Gently rotate or twist the joystick(s) you want to replace.
    • Apply some force and pull upward towards you.
    • You will know it is released when you hear a popping sound.
    • Place your new joystick and push it downwards; you will hear a popping sound again.
结论
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 57
总计 683
