跳转到主内容
PDP Rematch Action Buttons Replacement
你所需要的
  1. PDP Rematch Action Buttons Replacement, Faceplate: 步骤 1 中的图像 1,2 PDP Rematch Action Buttons Replacement, Faceplate: 步骤 1 中的图像 2,2
    • Grip one side of the controller firmly.
    • Insert an opening pick into the crease between the faceplate and the body of the controller.
    • Once the pick creates a gap in the crease, gently insert another pick into a different section of the crease.
    • Carefully move the picks along the controller's crease line until you hear a popping sound.
    • Gently lift off the faceplate by hand.
  2. PDP Rematch Action Buttons Replacement: 步骤 2 中的图像 1,2 PDP Rematch Action Buttons Replacement: 步骤 2 中的图像 2,2
    • Remove the 8 mm screws from the hard cover using a JIS #00 screwdriver.
    • Since the screws have been removed, avoid shaking or moving your controller too much to prevent other buttons from falling out.
  3. PDP Rematch Action Buttons Replacement: 步骤 3 中的图像 1,2 PDP Rematch Action Buttons Replacement: 步骤 3 中的图像 2,2
    • Gently lift off the hard cover with your hand; it should not need much force.
  4. PDP Rematch Action Buttons Replacement, Action Buttons: 步骤 4 中的图像 1,1
    • Optional: Use a cotton pad or cotton swab with some alcohol to gently clean any debris.
    • These buttons are not connected to the device and will fall out, so be careful.
  5. PDP Rematch Action Buttons Replacement: 步骤 5 中的图像 1,3 PDP Rematch Action Buttons Replacement: 步骤 5 中的图像 2,3 PDP Rematch Action Buttons Replacement: 步骤 5 中的图像 3,3
    • Carefully remove the buttons from the device and set them aside.
    • From here, you can do a deeper clean, or replace them.
    • The clear plate will not sit right or click into place if the buttons are not aligned straight.
结论
Katie Barnes
于01/17/24注册
85 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 15
过去 30 天: 56
总计 550
