跳转到主内容
PDP Afterglow Wired Xbox 360 Controller LEDs Replacement
你所需要的
  1. PDP Afterglow Wired Xbox 360 Controller LEDs Replacement, Case: 步骤 1 中的图像 1,2 PDP Afterglow Wired Xbox 360 Controller LEDs Replacement, Case: 步骤 1 中的图像 2,2
    • Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
  2. PDP Afterglow Wired Xbox 360 Controller LEDs Replacement: 步骤 2 中的图像 1,1
    • Using a plastic opening tool, pry the back cover from the front.
    • The covers should separate without needing a plastic opening tool, but in some cases you may need to use it.
  3. PDP Afterglow Wired Xbox 360 Controller LEDs Replacement: 步骤 3 中的图像 1,1
    • Remove the top cover from the bottom and place next to each other.
  4. PDP Afterglow Wired Xbox 360 Controller LEDs Replacement, LEDs: 步骤 4 中的图像 1,2 PDP Afterglow Wired Xbox 360 Controller LEDs Replacement, LEDs: 步骤 4 中的图像 2,2
    • Remove the logic board from the controller casing by lifting up and pulling out.
  5. PDP Afterglow Wired Xbox 360 Controller LEDs Replacement: 步骤 5 中的图像 1,1
    • Locate the LED (s) that needs to be replaced.
    • Once the LED has been located, flip the logic board to the other side and locate the pins associated with the LED that needs to be replaced.
  6. PDP Afterglow Wired Xbox 360 Controller LEDs Replacement: 步骤 6 中的图像 1,1
    • Desolder the LED from the logic board.
    • The soldering iron is very hot and can harm you or the device if used improperly.
结论
另外一个人完成了本指南。
Joi Officer
于09/17/15注册
283 声望
创作了2篇指南
团队
IUPUI, Team 3-1, Harley Fall 2015 IUPUI, Team 3-1, Harley Fall 2015 的会员
IUPUI-HARLEY-F15S3G1
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 24
总计 1,925
