跳转到主内容
PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement
你所需要的
  1. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement, Joysticks: 步骤 1 中的图像 1,1
    • Remove the two 11 mm screws from the back of the controller using a Phillips #0 screwdriver.
    • Remove the five 8 mm screws from the back of the controller using a Phillips #0 screwdriver.
  2. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: 步骤 2 中的图像 1,1
    • Remove the back cover from the controller and set it aside.
  3. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: 步骤 3 中的图像 1,1
    • Remove the circuit board from the front casing.
    • Be cautious of disconnecting the vibration motors which are attached by thin wires.
  4. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: 步骤 4 中的图像 1,3 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: 步骤 4 中的图像 2,3 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: 步骤 4 中的图像 3,3
    • Wiggle and pull the joystick until it comes off of the circuit board.
  5. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: 步骤 5 中的图像 1,2 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: 步骤 5 中的图像 2,2
    • Place the new joystick into position and press until the joystick makes a click.
  6. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: 步骤 6 中的图像 1,1
    • Place the circuit board and vibration motors back into the front casing.
  7. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: 步骤 7 中的图像 1,3 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: 步骤 7 中的图像 2,3 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: 步骤 7 中的图像 3,3
    • Place the back cover into position.
    • Reinsert the two 11 mm screws into the back of the controller using a Phillips #0 screwdriver.
    • Reinsert the five 8 mm screws into the back of the controller using a Phillips #0 screwdriver.
终点
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 12
过去 30 天: 74
总计 2,681
