跳转到主内容
PDP Afterglow Wired Xbox 360 Controller Cable Replacement
你所需要的
  1. PDP Afterglow Wired Xbox 360 Controller Cable Replacement, Case: 步骤 1 中的图像 1,2 PDP Afterglow Wired Xbox 360 Controller Cable Replacement, Case: 步骤 1 中的图像 2,2
    • Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
  2. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: 步骤 2 中的图像 1,1
    • Using a plastic opening tool, pry the back cover from the front.
    • The covers should separate without needing a plastic opening tool, but in some cases you may need to use it.
  3. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: 步骤 3 中的图像 1,1
    • Remove the top cover from the bottom and place next to each other.
  4. PDP Afterglow Wired Xbox 360 Controller Cable Replacement, Cable: 步骤 4 中的图像 1,2 PDP Afterglow Wired Xbox 360 Controller Cable Replacement, Cable: 步骤 4 中的图像 2,2
    • Remove the logic board by lifting up on the logic board and pulling out.
  5. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: 步骤 5 中的图像 1,1
    • The cable connects to the logic board with a white connector. Above the right joystick, there are four solder pins labeled GND, VCC, DM, and DP.
  6. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: 步骤 6 中的图像 1,1
    • The soldering iron is very hot and can harm you or the device if used incorrectly.
    • Desolder the four pins.
  7. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: 步骤 7 中的图像 1,1
    • Using your new cable, solder the white connector to the logic board. Be sure to have the cables facing towards the inside of the logic board.
结论
5等其他人完成本指南。
团队
IUPUI, Team 3-1, Harley Fall 2015 IUPUI, Team 3-1, Harley Fall 2015 的会员
IUPUI-HARLEY-F15S3G1
4 名成员
创作了5篇指南
4条评论
where can I find a replacement cable to perform this precedure with?
Aaron English - 回复
yes!! i would like to know too.. i have been searching for long time for that cable
sokratis162 -
Android cable
Wayne -
U can use a old Android cable
Wayne - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 48
总计 6,831
