跳转到主内容
PDP Afterglow Wired Xbox 360 Controller Button Replacement
你所需要的
  1. PDP Afterglow Wired Xbox 360 Controller Button Replacement, Case: 步骤 1 中的图像 1,2 PDP Afterglow Wired Xbox 360 Controller Button Replacement, Case: 步骤 1 中的图像 2,2
    • Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
  2. PDP Afterglow Wired Xbox 360 Controller Button Replacement: 步骤 2 中的图像 1,1
    • Using a plastic opening tool, pry the back cover from the front.
    • The covers should separate without needing a plastic opening tool, but in some cases you may need to use it.
  3. PDP Afterglow Wired Xbox 360 Controller Button Replacement: 步骤 3 中的图像 1,1
    • Remove the top cover from the bottom and place next to each other.
  4. PDP Afterglow Wired Xbox 360 Controller Button Replacement, Button: 步骤 4 中的图像 1,1
    • Remove the rubber button covers from the A, B, X, and Y buttons.
  5. PDP Afterglow Wired Xbox 360 Controller Button Replacement: 步骤 5 中的图像 1,2 PDP Afterglow Wired Xbox 360 Controller Button Replacement: 步骤 5 中的图像 2,2
    • Push up on the buttons from the front and pull them out from the back.
结论
4等其他人完成本指南。
Joi Officer
于09/17/15注册
298 声望
创作了2篇指南
团队
IUPUI, Team 3-1, Harley Fall 2015 IUPUI, Team 3-1, Harley Fall 2015 的会员
IUPUI-HARLEY-F15S3G1
4 名成员
创作了5篇指南
4指南评论
What about removing the Dpad? i really need help.
Elijah Douglas - 回复
I’m sorry but, I have to say that the reassembly process is harder than simply ‘follow the instructions in reverse’; if you try and place the half with the buttons, the buttons fall out or end up misaligned ; and if you use the other half, the rubber covers and the tumblers will fall out.
Again, this guild comes off a little too simple, there’s more to it.
Christopher Mali-Martinez - 回复
the circuit board comes off the other half. You can stack them very easily. You're simply incorrect.
Tyler Anderson -
No not really I agree with homeboy cause I just took mine apart to fix drifting and the one piece clip for RB and Lb doesn’t just fit in there right
David Drinkard - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 63
总计 6,059
