跳转到主内容
加入维修社区 - 创建账户
PCPanel Pro MIDI Controller Knob Replacement
你所需要的
  1. PCPanel Pro MIDI Controller Knob Replacement, Knob: 步骤 1 中的图像 1,2 PCPanel Pro MIDI Controller Knob Replacement, Knob: 步骤 1 中的图像 2,2
    • Unplug the device.
  2. PCPanel Pro MIDI Controller Knob Replacement: 步骤 2 中的图像 1,2 PCPanel Pro MIDI Controller Knob Replacement: 步骤 2 中的图像 2,2
    • Turn the affected knobs counter-clockwise until they cannot move anymore.
  3. PCPanel Pro MIDI Controller Knob Replacement: 步骤 3 中的图像 1,3 PCPanel Pro MIDI Controller Knob Replacement: 步骤 3 中的图像 2,3 PCPanel Pro MIDI Controller Knob Replacement: 步骤 3 中的图像 3,3
    • Slowly pull upwards on the knob until it slides off.
    • Not much force needs to be used.
  4. PCPanel Pro MIDI Controller Knob Replacement: 步骤 4 中的图像 1,3 PCPanel Pro MIDI Controller Knob Replacement: 步骤 4 中的图像 2,3 PCPanel Pro MIDI Controller Knob Replacement: 步骤 4 中的图像 3,3
    • Unscrew the fastening screw on the new knob until it is loose.
    • Depending on the knob, you may need to use a different tool to unscrew it. For the knob we had, we used a flathead screwdriver.
  5. PCPanel Pro MIDI Controller Knob Replacement: 步骤 5 中的图像 1,2 PCPanel Pro MIDI Controller Knob Replacement: 步骤 5 中的图像 2,2
    • Place the replacement knob onto the MIDI controller.
  6. PCPanel Pro MIDI Controller Knob Replacement: 步骤 6 中的图像 1,3 PCPanel Pro MIDI Controller Knob Replacement: 步骤 6 中的图像 2,3 PCPanel Pro MIDI Controller Knob Replacement: 步骤 6 中的图像 3,3
    • Screw the fastening screw into the MIDI controller. Make sure to leave a 2mm gap between the bottom of the replacement knob and the MIDI controller.
    • In this case, we used calipers to ensure the gap stayed at 2mm, however placing a few pieces of paper underneath the knob will be just fine. We are keeping this gap to ensure that the knob can still be pushed down.
  7. PCPanel Pro MIDI Controller Knob Replacement: 步骤 7 中的图像 1,3 PCPanel Pro MIDI Controller Knob Replacement: 步骤 7 中的图像 2,3 PCPanel Pro MIDI Controller Knob Replacement: 步骤 7 中的图像 3,3
    • Plug in the MIDI controller and test the replacement knob. Ensure the knob can still be turned in either direction as well as pushed down.
  8. PCPanel Pro MIDI Controller Knob Replacement: 步骤 8 中的图像 1,1
    • Repeat the steps for any replacement knobs needed.
    • Make sure all replaced knobs can still be turned in either direction as well as pushed down.
结论
Make sure all of the knobs function as intended. To remove the knobs and put the old ones on, simply do the steps in reverse.
William Orlopp
于04/15/24注册
157 声望
撰写一个指南
团队
UC Davis, Team 1-1, Morris Spring 2024 UC Davis, Team 1-1, Morris Spring 2024 的会员
UCD-MORRIS-S24S1G1
3 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 27
总计 323
