跳转到主内容
PCIe Fan Replacement guide
你所需要的
  1. PCIe Fan Replacement guide, Side Panel Removal: 步骤 1 中的图像 1,1
    • Begin by pulling up on the lever located at the back of the computer to remove the side panel.
  2. PCIe Fan Replacement guide, Hard drive removal: 步骤 2 中的图像 1,1
    • Gently pull outward on each of the four hard drive trays to remove them.
  3. PCIe Fan Replacement guide, Fan Removal: 步骤 3 中的图像 1,1
    • Remove the two 10mm PH #1 screws holding in the PCIe fan.
    • They are very tightened, if you do it wrong the screw might get stripped.
  4. PCIe Fan Replacement guide, Fan Removal: 步骤 4 中的图像 1,1
    • Gently pull the fan straight outward to remove it.
结论
6等其他人完成本指南。
Andrew Damiani
于07/30/17注册
236 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 35
总计 6,369
