跳转到主内容
加入维修社区 - 创建账户
PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets
你所需要的
    1. PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets, Cuff Buckle: 步骤 1 中的图像 1,1
      • Place the skate on a flat surface.
      询问修复机器人
      添加评论
    2. PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets: 步骤 2 中的图像 1,2 PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets: 步骤 2 中的图像 2,2
      • Locate the rivets on each side of the cuff buckle.
      • There should be 3 rivets in total.
      询问修复机器人
      添加评论
    3. PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets: 步骤 3 中的图像 1,3 PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets: 步骤 3 中的图像 2,3 PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets: 步骤 3 中的图像 3,3
      • Insert Pozidriv PZ2 screwdriver into the back of each rivet and twist until the rivet is shaved down enough to pop out. Repeat as needed.
      • Apply heavy pressure.
      • If there are issues removing rivets, use a power drill with an 11/32 inch bit.
      • If using a power drill for this process, avoid loose clothing, and tie back hair. Wear safety goggles for additional protection.
      询问修复机器人
      添加评论
    4. PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets: 步骤 4 中的图像 1,1
      • Stripping the rivets will produce metal shavings and dust. Use caution and dispose of them in the trash.
      询问修复机器人
      添加评论
    5. PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets: 步骤 5 中的图像 1,1
      • Remove the plastic part of the cuff buckle with the attached cuff and discard.
      询问修复机器人
      添加评论
    6. PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets: 步骤 6 中的图像 1,2 PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets: 步骤 6 中的图像 2,2
      • Your skate will look like this once they are removed. There are two ways to attach the new cuff buckle:
      • If your new cuff buckle comes with rivets, please use this guide.
      • If your new cuff buckle comes with screws, please use this guide.
      询问修复机器人
      添加评论
    1. PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets, Cuff Buckle With Rivets: 步骤 7 中的图像 1,1
      询问修复机器人
      添加评论
    2. PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets: 步骤 8 中的图像 1,1
      • Align the cuff buckle with the strap on the outside holes.
      询问修复机器人
      添加评论
    3. PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets: 步骤 9 中的图像 1,1
      • Insert the rivet into the first hole from the outside completely until flush with the skate.
      询问修复机器人
      添加评论
    4. PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets: 步骤 10 中的图像 1,3 PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets: 步骤 10 中的图像 2,3 PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets: 步骤 10 中的图像 3,3
      • Insert the long, straight rivet into the rivet gun until it's completely covered.
      • Squeeze the rivet gun repeatedly, until it detaches from the rivet.
      • You will hear a pop.
      • Discard the detached metal rod.
      询问修复机器人
      添加评论
    5. PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets: 步骤 11 中的图像 1,2 PAPAISON Adjustable Inline Skates Cuff Buckle Replacement With Rivets: 步骤 11 中的图像 2,2
      • Repeat for each remaining rivet placement.
      • Following completion of remaining rivets, your new cuff buckle will be fully attached.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Johnnie B.
于09/25/25注册
602 声望
创作了5篇指南
团队
Texas Tech, Team 41-3, Allen Fall 2025 Texas Tech, Team 41-3, Allen Fall 2025 的会员
TTU-ALLEN-F25S41G3
3 名成员
创作了60篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 27
总计 215
