跳转到主内容
修复你的物品
维修的权力
商店
简介
How to fix a squeaky Water flow
配件
没有特定配件。
  1. Warning: Bevore working at it unplug the Power. Here you can see the plastic tube  from where the water comes. it is clipped in a claer plastic shape OPen the two clips an pull it down and shake it a little so teh tube can get out of it.
    • Warning: Bevore working at it unplug the Power. Here you can see the plastic tube from where the water comes. it is clipped in a claer plastic shape
    • OPen the two clips an pull it down and shake it a little so teh tube can get out of it.
    • This clear plastic is fragile, be careful or the clips may break.
  2. More pictures of the clear plastic part and its clipse. If you don't want to clean it you can skip this step. i used citric acid and a brush to clean it from calc. If you don't want to clean it you can skip this step. i used citric acid and a brush to clean it from calc.
    • More pictures of the clear plastic part and its clipse.
    • If you don't want to clean it you can skip this step. i used citric acid and a brush to clean it from calc.
  3. How to open - three steps: First step: remove the TWO PH2 screws on left and right sides. They have same length. Second step: PULL the complete display/touch-part for about one or two centimeters. rattel and shake a liitle because the flap to the icecrusher  could be frosted. Third step: Now pull it downwards and shake it a littlebit. On the left is the cable, it is not neccessary to unplug it. now turn around and you see the plastic from the lever.
    • How to open - three steps: First step: remove the TWO PH2 screws on left and right sides. They have same length.
    • Second step: PULL the complete display/touch-part for about one or two centimeters. rattel and shake a liitle because the flap to the icecrusher could be frosted.
    • Third step: Now pull it downwards and shake it a littlebit. On the left is the cable, it is not neccessary to unplug it. now turn around and you see the plastic from the lever.
  4. This is the backside. the quadratic black rubber part is the motorized flap of the icecrusher. be careful, ther are some springs, dont loose them.
    • This is the backside. the quadratic black rubber part is the motorized flap of the icecrusher. be careful, ther are some springs, dont loose them.
    • Now, Spray some Silcone-Spray on the moving parts. i have made red circles where i have put on the Spray. just a lille bit, also on the spring.
    • Try, move it, when its still noisy apply more silconespray while moving it in and out.
    • Thats it. reasemble, as last step clip on the clear plastic on the tube from the water, then the notches and then the clipse.
    • done :)
结论
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
2等其他人完成本指南。
Schwarzstein
于2013年07月15日注册
2,445 信誉积分
创作了14篇指南
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 4
过去的30天: 22
总计 1,098
