你所需要的
Unscrew the two screws circled in red
Slide the plate in the direction of the arrow
Unscrew the screw circled in red
Lift the disc with the green tab
Remove the disc in the direction of the arrow
Disconnect the two connectors circled in green
Remove the WLAN card
Unscrew the four large screws circled in green
Unscrew the five small screws circled in red
Lift the cooler with the two tabs circled in blue
Lift the flap that holds the two connectors framed in red
Disconnect the two framed connectors in red
To reassemble your device, follow the instructions in reverse order.
另外一个人完成了本指南。
由衷感谢以下译者:
100%
irlanda正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
