跳转到主内容
Ozeri Pronto ZK14-S LCD Replacement
你所需要的
  1. Ozeri Pronto ZK14-S LCD Replacement, Panel Removal: 步骤 1 中的图像 1,2 Ozeri Pronto ZK14-S LCD Replacement, Panel Removal: 步骤 1 中的图像 2,2
    • Twist the plastic plate slowly to the left to pull it away.
  2. Ozeri Pronto ZK14-S LCD Replacement: 步骤 2 中的图像 1,1
    • Lift up the sticker at the bottom where the “Ozeri” logo is to reveal a screw.
    • The sticker does not need to be completely removed.
  3. Ozeri Pronto ZK14-S LCD Replacement: 步骤 3 中的图像 1,1
    • Using a 2.0 Flathead screwdriver, remove the 9.50 mm Phillips head screw under the sticker.
  4. Ozeri Pronto ZK14-S LCD Replacement: 步骤 4 中的图像 1,2 Ozeri Pronto ZK14-S LCD Replacement: 步骤 4 中的图像 2,2
    • Using a 2.0 Flathead screwdriver, remove the two 18.76 mm Phillips head screws in the plate stand.
  5. Ozeri Pronto ZK14-S LCD Replacement: 步骤 5 中的图像 1,2 Ozeri Pronto ZK14-S LCD Replacement: 步骤 5 中的图像 2,2
    • Using a 2.0 Flathead screwdriver, remove the 9.44 mm Phillips head screw on the edge opposite to the LCD screen.
  6. Ozeri Pronto ZK14-S LCD Replacement: 步骤 6 中的图像 1,1
    • Turn the device over so the back panel is facing up.
  7. Ozeri Pronto ZK14-S LCD Replacement: 步骤 7 中的图像 1,1
    • Using the iFixit opening tool, pry off the two rubber stubs on the right side and the two rubber stubs on the left side of the bottom of the device.
  8. Ozeri Pronto ZK14-S LCD Replacement: 步骤 8 中的图像 1,1
    • Using a 2.0 Flathead screwdriver, remove the four 9.46 mm Phillips head screws that were under the rubber stubs.
  9. Ozeri Pronto ZK14-S LCD Replacement: 步骤 9 中的图像 1,2 Ozeri Pronto ZK14-S LCD Replacement: 步骤 9 中的图像 2,2
    • Pry apart the two panels to separate them from each other.
    • Flip the device over so the LCD is facing up. Flip the front panel over on its side.
    • Be careful when separating the panels to avoid damaging the wires they are connected by.
  10. Ozeri Pronto ZK14-S LCD Replacement, LCD: 步骤 10 中的图像 1,2 Ozeri Pronto ZK14-S LCD Replacement, LCD: 步骤 10 中的图像 2,2
    在这个步骤中使用的工具:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    购买
    • Using the 2.0 Flathead screwdriver, remove the three 7.20 mm screw on the back of the center LCD motherboard.
  11. Ozeri Pronto ZK14-S LCD Replacement: 步骤 11 中的图像 1,3 Ozeri Pronto ZK14-S LCD Replacement: 步骤 11 中的图像 2,3 Ozeri Pronto ZK14-S LCD Replacement: 步骤 11 中的图像 3,3
    • Stand the center motherboard up to expose the LCD screen
    • Be careful when standing up the LCD motherboard to avoid damaging the wires it is connected to.
    • Remove the LCD screen.
结论
3等其他人完成本指南。
Oneika White
于10/01/15注册
709 声望
创作了4篇指南
团队
USF Tampa, Team 1-4, Leahy Fall 2015 USF Tampa, Team 1-4, Leahy Fall 2015 的会员
USFT-LEAHY-F15S1G4
4 名成员
创作了5篇指南
一条评论
I had a similar model, it was different to open but the LCD was showing all 8's, I just reset the same LCD and it worked like new.
Dennis Lima - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 580
