跳转到主内容
Ozeri Pronto ZK14-S Panel Removal Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. Ozeri Pronto ZK14-S  Panel Removal  Replacement, Panel Removal: 步骤 1 中的图像 1,2 Ozeri Pronto ZK14-S  Panel Removal  Replacement, Panel Removal: 步骤 1 中的图像 2,2
    • Twist the plastic plate slowly to the left to pull it away.
  2. Ozeri Pronto ZK14-S  Panel Removal  Replacement: 步骤 2 中的图像 1,1
    • Lift up the sticker at the bottom where the “Ozeri” logo is to reveal a screw.
    • The sticker does not need to be completely removed.
  3. Ozeri Pronto ZK14-S  Panel Removal  Replacement: 步骤 3 中的图像 1,1
    • Using a 2.0 Flathead screwdriver, remove the 9.50 mm Phillips head screw under the sticker.
  4. Ozeri Pronto ZK14-S  Panel Removal  Replacement: 步骤 4 中的图像 1,2 Ozeri Pronto ZK14-S  Panel Removal  Replacement: 步骤 4 中的图像 2,2
    • Using a 2.0 Flathead screwdriver, remove the two 18.76 mm Phillips head screws in the plate stand.
  5. Ozeri Pronto ZK14-S  Panel Removal  Replacement: 步骤 5 中的图像 1,2 Ozeri Pronto ZK14-S  Panel Removal  Replacement: 步骤 5 中的图像 2,2
    • Using a 2.0 Flathead screwdriver, remove the 9.44 mm Phillips head screw on the edge opposite to the LCD screen.
  6. Ozeri Pronto ZK14-S  Panel Removal  Replacement: 步骤 6 中的图像 1,1
    • Turn the device over so the back panel is facing up.
  7. Ozeri Pronto ZK14-S  Panel Removal  Replacement: 步骤 7 中的图像 1,1
    • Using the iFixit opening tool, pry off the two rubber stubs on the right side and the two rubber stubs on the left side of the bottom of the device.
  8. Ozeri Pronto ZK14-S  Panel Removal  Replacement: 步骤 8 中的图像 1,1
    • Using a 2.0 Flathead screwdriver, remove the four 9.46 mm Phillips head screws that were under the rubber stubs.
  9. Ozeri Pronto ZK14-S  Panel Removal  Replacement: 步骤 9 中的图像 1,2 Ozeri Pronto ZK14-S  Panel Removal  Replacement: 步骤 9 中的图像 2,2
    • Pry apart the two panels to separate them from each other.
    • Flip the device over so the LCD is facing up. Flip the front panel over on its side.
    • Be careful when separating the panels to avoid damaging the wires they are connected by.
结论
AshleyKreisel
于10/01/15注册
101 声望
撰写一个指南
团队
USF Tampa, Team 1-4, Leahy Fall 2015 USF Tampa, Team 1-4, Leahy Fall 2015 的会员
USFT-LEAHY-F15S1G4
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 61
