跳转到主内容
加入维修社区 - 创建账户
Overalls Buckle Replacement
你所需要的
  1. Overalls Buckle Replacement, Overalls Buckle: 步骤 1 中的图像 1,1
    • Lay the overalls on a flat surface with the straps folded forward.
  2. Overalls Buckle Replacement: 步骤 2 中的图像 1,1
    • Seam rippers or similar tools are sharp and can cause injury. Use with caution.
    • Only complete this step if previous buckles are currently sewn on in any fashion. If the strap has no buckle, skip this step.
    • Use a seam ripper to cut the existing seam on the strap near the buckle.
  3. Overalls Buckle Replacement: 步骤 3 中的图像 1,1
    • Unthread the strap by pulling the now-freed end through the loops in the buckle and adjuster.
  4. Overalls Buckle Replacement: 步骤 4 中的图像 1,3 Overalls Buckle Replacement: 步骤 4 中的图像 2,3 Overalls Buckle Replacement: 步骤 4 中的图像 3,3
    • With the new buckle set (clip and adjuster), thread the strap first, around the center bar of the adjuster.
    • Be sure the strap wraps up through the back of the adjuster, then down through the front (relative to the overalls), this way the adjuster will be the correct orientation when this step is complete.
  5. Overalls Buckle Replacement: 步骤 5 中的图像 1,3 Overalls Buckle Replacement: 步骤 5 中的图像 2,3 Overalls Buckle Replacement: 步骤 5 中的图像 3,3
    • Thread the strap through the buckle. Wrap the strap around the center slider, similar to the previous step.
    • Next thread the strap up through the center slider and then out the remaining hole.
  6. Overalls Buckle Replacement: 步骤 6 中的图像 1,2 Overalls Buckle Replacement: 步骤 6 中的图像 2,2
    • Thread the strap through the adjuster as in step 4, although now backwards and underneath the existing strap.
  7. Overalls Buckle Replacement: 步骤 7 中的图像 1,2 Overalls Buckle Replacement: 步骤 7 中的图像 2,2
    • Needles are sharp and can cause injury, particularly when sewing tough materials like denim. Use with caution.
    • With about an inch of slack, fold the strap end back onto itself. This should create a small loop containing the center slider of the adjuster.
    • Using a needle and thread, hand sew across the strap, permanently closing this loop.
    • The stitches do not have to be perfect. When the overalls are worn, these stitches will not be visible.
  8. Overalls Buckle Replacement: 步骤 8 中的图像 1,1
    • Using the needle, tie two to three simple, overhand knots to secure the stitching and cut off remaining slack.
终点
Max Waldorf
于01/26/23注册
165 声望
撰写一个指南
团队
UC Davis, Team 2-12, Morris Winter 2023 UC Davis, Team 2-12, Morris Winter 2023 的会员
UCD-MORRIS-W23S2G12
2 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 39
过去 30 天: 183
总计 6,417
