跳转到主内容
Ovation Acoustic Guitar String Replacement
你所需要的
  1. Ovation Acoustic Guitar String Replacement, Guitar String: 步骤 1 中的图像 1,1
    • Place the guitar neck where you can easily identify the broken string.
  2. Ovation Acoustic Guitar String Replacement: 步骤 2 中的图像 1,2 Ovation Acoustic Guitar String Replacement: 步骤 2 中的图像 2,2
    • Place the guitar neck on an elevated surface (ex. bundle towels, pillow, etc.). Remove the string with a string winder until it is loose enough to pull out by hand.
  3. Ovation Acoustic Guitar String Replacement: 步骤 3 中的图像 1,1
    • Take the string out carefully and begin to pull the string out through the bridge which is at the lower end of the guitar.
  4. Ovation Acoustic Guitar String Replacement: 步骤 4 中的图像 1,2 Ovation Acoustic Guitar String Replacement: 步骤 4 中的图像 2,2
    • Once the string is removed, wipe down the guitar neck to prevent further oil buildup.
  5. Ovation Acoustic Guitar String Replacement: 步骤 5 中的图像 1,1
    • Layout the new guitar strings from biggest to smallest.
  6. Ovation Acoustic Guitar String Replacement: 步骤 6 中的图像 1,3 Ovation Acoustic Guitar String Replacement: 步骤 6 中的图像 2,3 Ovation Acoustic Guitar String Replacement: 步骤 6 中的图像 3,3
    • Pull the new string through the bridge until the stopper is flushed with the bridge.
  7. Ovation Acoustic Guitar String Replacement: 步骤 7 中的图像 1,2 Ovation Acoustic Guitar String Replacement: 步骤 7 中的图像 2,2
    • Position the skinny side of the string into the tuning peg. Allow enough excess string ( about 3 inches) so when the string is tightened, it will not break from being too tight or break from being too loose.
  8. Ovation Acoustic Guitar String Replacement: 步骤 8 中的图像 1,3 Ovation Acoustic Guitar String Replacement: 步骤 8 中的图像 2,3 Ovation Acoustic Guitar String Replacement: 步骤 8 中的图像 3,3
    • Loop the excess guitar string around the tuning peg and make sure the coil is being tuned downwards.
  9. Ovation Acoustic Guitar String Replacement: 步骤 9 中的图像 1,2 Ovation Acoustic Guitar String Replacement: 步骤 9 中的图像 2,2
    • Trim the excess string with pliers. Make sure it is cut as close to the tuning peg so it does not stick out.
终点
Rachel Galvan
于04/07/21注册
169 声望
撰写一个指南
团队
CSU Los Angeles, Team S1-G6, Harris Fall 2021 CSU Los Angeles, Team S1-G6, Harris Fall 2021 的会员
CSULA-HARRIS-F21S1G6
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 10
总计 870
