跳转到主内容
Outer Shell Removal
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独使用。
你所需要的
  1. Outer Shell Removal, Reposition the head strap: 步骤 1 中的图像 1,2 Outer Shell Removal, Reposition the head strap: 步骤 1 中的图像 2,2
    • Rotate the head strap forward as far as it will go.
  2. Outer Shell Removal, Unplug the All-In-One Cable: 步骤 2 中的图像 1,2 Outer Shell Removal, Unplug the All-In-One Cable: 步骤 2 中的图像 2,2
    • Unplug the All-In-One Cable from your headset.
  3. Outer Shell Removal, Remove the All-In-One Cable: 步骤 3 中的图像 1,3 Outer Shell Removal, Remove the All-In-One Cable: 步骤 3 中的图像 2,3 Outer Shell Removal, Remove the All-In-One Cable: 步骤 3 中的图像 3,3
    • Remove the All-In-One Cable from the cable guides along the left side of the head strap.
    • During reassembly, connect the All-In-One Cable to the headset before routing it through the cable guides. This will ensure it has the right amount of slack.
  4. Outer Shell Removal, Remove the top strap: 步骤 4 中的图像 1,2 Outer Shell Removal, Remove the top strap: 步骤 4 中的图像 2,2
    • Separate the top strap from itself where the Velcro secures it.
  5. Outer Shell Removal: 步骤 5 中的图像 1,3 Outer Shell Removal: 步骤 5 中的图像 2,3 Outer Shell Removal: 步骤 5 中的图像 3,3
    • Peel back the Velcro securing the rear of the top strap.
    • Feed the top strap out through the head strap to partially remove it.
  6. Outer Shell Removal: 步骤 6 中的图像 1,3 Outer Shell Removal: 步骤 6 中的图像 2,3 Outer Shell Removal: 步骤 6 中的图像 3,3
    • Feed the top strap through the clip near the front of headset to fully remove it.
  7. Outer Shell Removal, Remove the front side foam pads: 步骤 7 中的图像 1,3 Outer Shell Removal, Remove the front side foam pads: 步骤 7 中的图像 2,3 Outer Shell Removal, Remove the front side foam pads: 步骤 7 中的图像 3,3
    • Peel off both front side foam pads to uncover the speaker wires.
  8. Outer Shell Removal, Remove the two rubber spacers: 步骤 8 中的图像 1,3 Outer Shell Removal, Remove the two rubber spacers: 步骤 8 中的图像 2,3 Outer Shell Removal, Remove the two rubber spacers: 步骤 8 中的图像 3,3
    • Use the point of your spudger to pry out the two rubber spacers next to the headphone screws.
    • Be careful not to accidentally pry any of the speaker wires under the rubber spacer.
  9. Outer Shell Removal, Disconnect the speaker wires: 步骤 9 中的图像 1,3 Outer Shell Removal, Disconnect the speaker wires: 步骤 9 中的图像 2,3 Outer Shell Removal, Disconnect the speaker wires: 步骤 9 中的图像 3,3
    • Use the point of your spudger to pry up and disconnect both the left and right headphone speaker wires.
  10. Outer Shell Removal, Remove the head strap: 步骤 10 中的图像 1,2 Outer Shell Removal, Remove the head strap: 步骤 10 中的图像 2,2
    • Use a T6 Torx screwdriver to remove the two 12.1 mm screws (one on each side) securing the head strap to the headset.
    • Use a T5 Torx screwdriver to remove the following screws securing the head strap to the headset:
    • Four 3.9 mm screws (two on each side)
    • Two 4.1 mm screws (one on each side)
  11. Outer Shell Removal: 步骤 11 中的图像 1,1
    • Remove the two plastic spacers underneath the previously removed Torx T6 screw.
  12. Outer Shell Removal: 步骤 12 中的图像 1,3 Outer Shell Removal: 步骤 12 中的图像 2,3 Outer Shell Removal: 步骤 12 中的图像 3,3
    • Thread the headphone speaker wires out through both ends of the head strap.
  13. Outer Shell Removal, Remove the outer shell: 步骤 13 中的图像 1,3 Outer Shell Removal, Remove the outer shell: 步骤 13 中的图像 2,3 Outer Shell Removal, Remove the outer shell: 步骤 13 中的图像 3,3
    • The four screws securing the outer shell are covered with black stickers. If the stickers are difficult to remove, simply press your T6 Torx driver through them.
  14. Outer Shell Removal: 步骤 14 中的图像 1,2 Outer Shell Removal: 步骤 14 中的图像 2,2
    • Use a T6 Torx screwdriver to remove the four 3.9 mm screws (two on top, two on bottom) securing the outer shell to the headset.
  15. Outer Shell Removal: 步骤 15 中的图像 1,3 Outer Shell Removal: 步骤 15 中的图像 2,3 Outer Shell Removal: 步骤 15 中的图像 3,3
    • Insert an opening pick into the seam between the two halves of the outer shell.
    • Slide the opening pick through the seam to dislodge the clips securing it to the headset.
    • Only insert the opening pick as far as necessary. There are ribbon cables underneath the outer shell.
  16. Outer Shell Removal: 步骤 16 中的图像 1,3 Outer Shell Removal: 步骤 16 中的图像 2,3 Outer Shell Removal: 步骤 16 中的图像 3,3
    • Continue sliding the opening pick through each seam until all clips have been dislodged.
  17. Outer Shell Removal: 步骤 17 中的图像 1,3 Outer Shell Removal: 步骤 17 中的图像 2,3 Outer Shell Removal: 步骤 17 中的图像 3,3
    • Carefully slide each half of the outer shell off of the sensor array.
    • Be careful not to snag any of the ribbon cables underneath.
结论
Sam Omiotek
于02/25/19注册
85,411 声望
创作了290篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 398
