跳转到主内容
加入维修社区 - 创建账户
Outdoor Gate Deadbolt Replacement
你所需要的
  1. Outdoor Gate Deadbolt Replacement, Deadbolt: 步骤 1 中的图像 1,3 Outdoor Gate Deadbolt Replacement, Deadbolt: 步骤 1 中的图像 2,3 Outdoor Gate Deadbolt Replacement, Deadbolt: 步骤 1 中的图像 3,3
    • Remove the old deadbolt.
    • The gate should look like this before you begin installing the new deadbolt
  2. Outdoor Gate Deadbolt Replacement: 步骤 2 中的图像 1,3 Outdoor Gate Deadbolt Replacement: 步骤 2 中的图像 2,3 Outdoor Gate Deadbolt Replacement: 步骤 2 中的图像 3,3
    • From the front side of the gate, push the latch into the center of the opening. Adjust as needed.
    • Screw both of the short screws into the panel to the right of the latch.
  3. Outdoor Gate Deadbolt Replacement: 步骤 3 中的图像 1,3 Outdoor Gate Deadbolt Replacement: 步骤 3 中的图像 2,3 Outdoor Gate Deadbolt Replacement: 步骤 3 中的图像 3,3
    • Grab both of the long screws.
    • Adjust the back head of the doorknob to be facing in a straight upward position.
    • Screw in the long screws.
    • Make sure the screws are properly tightened.
  4. Outdoor Gate Deadbolt Replacement: 步骤 4 中的图像 1,2 Outdoor Gate Deadbolt Replacement: 步骤 4 中的图像 2,2
    • The back end and the front face of the deadbolt must line up.
    • Screw in the screws until they are fully tightened.
  5. Outdoor Gate Deadbolt Replacement: 步骤 5 中的图像 1,2 Outdoor Gate Deadbolt Replacement: 步骤 5 中的图像 2,2
    • Test out the new deadbolt with a key or door handle, depending on which one you may have.
结论
另外一个人完成了本指南。
Kenneth
于03/20/24注册
121 声望
撰写一个指南
团队
CSU Los Angeles, Team 1-26, Harris Spring 2024 CSU Los Angeles, Team 1-26, Harris Spring 2024 的会员
CSULA-HARRIS-S24S1G26
1 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 27
过去 30 天: 148
总计 2,054
