跳转到主内容
Oster Expressbake CKSTBRTW20 Inner Chamber Replacement
你所需要的
  1. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement, Top Panel Removal: 步骤 1 中的图像 1,1
    • Remove the bread pan.
  2. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: 步骤 2 中的图像 1,3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: 步骤 2 中的图像 2,3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: 步骤 2 中的图像 3,3
    • Remove the eight 22mm Phillips #1 screws from the grey lining.
    • Remove the grey liner.
  3. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: 步骤 3 中的图像 1,2 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: 步骤 3 中的图像 2,2
    • Remove the two 11mm Phillips #1 screws from the back of the device.
  4. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: 步骤 4 中的图像 1,2 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: 步骤 4 中的图像 2,2
    • Pop off the top case using a spudger.
    • Keep the spudger away from the control panel.
    • Be aware of wires connecting the microcontroller to the panel when removing the top lining.
  5. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement, Inner Chamber: 步骤 5 中的图像 1,3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement, Inner Chamber: 步骤 5 中的图像 2,3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement, Inner Chamber: 步骤 5 中的图像 3,3
    • Disconnect microcontroller and top lining.
    • Ground yourself prior to disconnecting in order to avoid harming the inner electronics.
  6. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: 步骤 6 中的图像 1,3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: 步骤 6 中的图像 2,3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: 步骤 6 中的图像 3,3
    • Remove the four 11mm Phillips #1 screws holding from the guard and inner lining.
    • Remove small rectangular guard from bottom of liner
  7. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: 步骤 7 中的图像 1,1
    • Remove the inner liner.
    • The inner liner will be connected to the outer chamber with wires.
  8. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: 步骤 8 中的图像 1,3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: 步骤 8 中的图像 2,3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: 步骤 8 中的图像 3,3
    • Disconnect the red wires from the inner liner.
  9. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: 步骤 9 中的图像 1,2 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: 步骤 9 中的图像 2,2
    • Remove the single 11mm Phillips #1 screw thats holding and inner lining in place.
  10. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: 步骤 10 中的图像 1,3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: 步骤 10 中的图像 2,3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: 步骤 10 中的图像 3,3
    • Use a spudger to push out the connector found on the inner lining.
  11. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: 步骤 11 中的图像 1,2 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: 步骤 11 中的图像 2,2
    • Remove lining.
结论
另外一个人完成了本指南。
Megan Saunders
于01/25/18注册
701 声望
创作了5篇指南
团队
USF Tampa, Team S7-G5, Passmore Spring 2018 USF Tampa, Team S7-G5, Passmore Spring 2018 的会员
USFT-PASSMORE-S18S7G5
4 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 540
