当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Flip the base unit over.
Remember to unplug your rice cooker before proceeding with teardown.
Remove the two Phillips screws.
Set aside all screws, keeping them in order by steps to help reconstruction.
Remove the bottom cover.
Remove the single Phillips Screw.
Bend the tabs inward with needle nose pliers to mirror the shape of the hole below it.
Be careful not to bend these tabs too much or too far, for they break off easily if bent back and forth too many times.
Lift the lever out of the tab.
Carefully pull the front panel and lever out the front of the base.
Remove the nut using an adjustable wrench.
Remove the power connector extender.
Remove the three Phillips Screws.
This screw is slightly longer than the other two.
The heating coil will fall out after the removal of the last screw. Holding the coil while unscrewing the last screw is suggested to prevent damage to the coil.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
