跳转到主内容
Oster DuraCeramic Titanium Infused 6-Cup Rice and Grain Cooker with Steamer Disassembly
你所需要的
  1. Oster DuraCeramic  Titanium Infused 6-Cup Rice and Grain Cooker with Steamer Disassembly, Accessories: 步骤 1 中的图像 1,1
    • Remove the lid, steamer pot, and tray from the base unit.
  2. Oster DuraCeramic  Titanium Infused 6-Cup Rice and Grain Cooker with Steamer Disassembly, Bottom Cover: 步骤 2 中的图像 1,2 Oster DuraCeramic  Titanium Infused 6-Cup Rice and Grain Cooker with Steamer Disassembly, Bottom Cover: 步骤 2 中的图像 2,2
    • Flip the base unit over.
    • Remember to unplug your rice cooker before proceeding with teardown.
    • Remove the two Phillips screws.
    • Set aside all screws, keeping them in order by steps to help reconstruction.
    • Remove the bottom cover.
  3. Oster DuraCeramic  Titanium Infused 6-Cup Rice and Grain Cooker with Steamer Disassembly, Fuse: 步骤 3 中的图像 1,2 Oster DuraCeramic  Titanium Infused 6-Cup Rice and Grain Cooker with Steamer Disassembly, Fuse: 步骤 3 中的图像 2,2
    • Remove the three Phillips screws
    • Remove the fuse from the unit.
  4. Oster DuraCeramic  Titanium Infused 6-Cup Rice and Grain Cooker with Steamer Disassembly, Front Panel and Lever: 步骤 4 中的图像 1,1
    • Flip the unit over.
    • Flip the unit back over.
  5. Oster DuraCeramic  Titanium Infused 6-Cup Rice and Grain Cooker with Steamer Disassembly, Front Panel and Lever: 步骤 5 中的图像 1,3 Oster DuraCeramic  Titanium Infused 6-Cup Rice and Grain Cooker with Steamer Disassembly, Front Panel and Lever: 步骤 5 中的图像 2,3 Oster DuraCeramic  Titanium Infused 6-Cup Rice and Grain Cooker with Steamer Disassembly, Front Panel and Lever: 步骤 5 中的图像 3,3
    • Remove the single Phillips Screw.
    • Bend the tabs inward with needle nose pliers to mirror the shape of the hole below it.
    • Be careful not to bend these tabs too much or too far, for they break off easily if bent back and forth too many times.
    • Lift the lever out of the tab.
    • Carefully pull the front panel and lever out the front of the base.
  6. Oster DuraCeramic  Titanium Infused 6-Cup Rice and Grain Cooker with Steamer Disassembly, Circuit Board: 步骤 6 中的图像 1,2 Oster DuraCeramic  Titanium Infused 6-Cup Rice and Grain Cooker with Steamer Disassembly, Circuit Board: 步骤 6 中的图像 2,2
    • Remove the Phillips screw.
    • Carefully remove the circuit board from the front panel.
  7. Oster DuraCeramic  Titanium Infused 6-Cup Rice and Grain Cooker with Steamer Disassembly, Heating Coil: 步骤 7 中的图像 1,1
    • Remove the nut using an adjustable wrench.
    • Remove the power connector extender.
    • Remove the three Phillips Screws.
    • This screw is slightly longer than the other two.
    • The heating coil will fall out after the removal of the last screw. Holding the coil while unscrewing the last screw is suggested to prevent damage to the coil.
  8. Oster DuraCeramic  Titanium Infused 6-Cup Rice and Grain Cooker with Steamer Disassembly, Thermomagnet: 步骤 8 中的图像 1,2 Oster DuraCeramic  Titanium Infused 6-Cup Rice and Grain Cooker with Steamer Disassembly, Thermomagnet: 步骤 8 中的图像 2,2
    • Bend the three tabs flat.
    • Remove the thermomagnet assembly from the heating coil.
结论
Michael Chan
于04/14/15注册
2,336 声望
创作了4篇指南
团队
Cal Poly, Team 6-16, Maness Spring 2015 Cal Poly, Team 6-16, Maness Spring 2015 的会员
CPSU-MANESS-S15S6G16
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 11
总计 302
