跳转到主内容
Oster Blend-N-Go My Blend Drinking Lid Seal Replacement
你所需要的
  1. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement, Blender Bottle: 步骤 1 中的图像 1,2 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement, Blender Bottle: 步骤 1 中的图像 2,2
    • Grip the blender base with one hand and blender bottle with the other hand.
    • Rotate the blender bottle a quarter turn counterclockwise .
    • Lift the blender bottle out of the blender base. The blade assembly should still be attached to the blender bottle.
  2. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: 步骤 2 中的图像 1,3 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: 步骤 2 中的图像 2,3 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: 步骤 2 中的图像 3,3
    • Grip the blade assembly with one hand and blender bottle with the other hand.
    • Rotate the blade assembly counterclockwise until it is completely unscrewed from the blender bottle.
    • Lift the blender bottle to separate it from the blade assembly.
  3. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement, Drinking Lid Assembly: 步骤 3 中的图像 1,1
    • After removing the blade assembly from the blender bottle, ensure that your drinking lid assembly has its seal placed in the seal bed.
  4. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: 步骤 4 中的图像 1,3 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: 步骤 4 中的图像 2,3 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: 步骤 4 中的图像 3,3
    • Grab the blender bottle with one hand and the drinking lid assembly with the other.
    • Place the drinking lid assembly onto the blender bottle and twist it clockwise until it is tight around the blender bottle.
  5. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement, Drinking Lid Seal: 步骤 5 中的图像 1,1
    • After separating the drinking lid assembly from the blender bottle, position the plastic opening tool on either side of the seal in the drinking lid assembly.
    • Wedge the tool between seal and seal seat wall.
  6. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: 步骤 6 中的图像 1,2 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: 步骤 6 中的图像 2,2
    • Gently pry the seal up while lifting seal out of the seal seat.
  7. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: 步骤 7 中的图像 1,2 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: 步骤 7 中的图像 2,2
    • Press new seal into seal seat with finger.
结论
另外一个人完成了本指南。
Paul Long
于08/27/15注册
710 声望
创作了4篇指南
团队
USF Tampa, Team 12-6, Blackwell Fall 2015 USF Tampa, Team 12-6, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S12G6
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 831
